C5 rear brakes vs. f-body rear brakes
Are the C5 rear calipers/brackets the same as the 98-02 f-body rear calipers/brackets?
I'd rather buy matching red rear calipers to my front C5 Z06 calipers if possible (as opposed to painting the ones I have and them not matching).
I used c5 pads and c5 clips...just go to autozone and get the rear pad clip kit for a c5 vette rather than cutting up the f-body ones. Everything went right together with the fbody brackets perfectly.
Did putting the rear C5 calipers shift the brake bias to the rear any? It was discussed in a thread I started a week or so ago so I thought I would check with you.
You have any pics? I would like to see it.
Did you use the C5 or f body rotors?
Caliper piston size is the same between the two calipers. So the bias will not change, You have to use the F-bod rotors, the C5 rotors have a diff offset and will not work. If you are going to put new pads on go with the GM performance ceramic they come with new spring clips and are a very clean pad.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
The mounting holes on the brackets will not line up. I would just recommend save your cash and get the rears powder coated to match the front! Their is very little performance difference compared to the stock other than the nice looks.
That's just my opinion.
Thanks
Brad
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Hello
Thanks
Brad![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks
Brad
Are you talking about the C5 brackets not lining up on the f body?
As toadzq8 stated the piston size is the same as an fbody so there is no change in bias. You cannot use the C5 rotor and there is no bracket kit to use that rotor that I know of. Basically switching to a C5 caliper in the rear is a cosmetic mod....
Switching to rear c5 calipers is mostly just to match the front conversion(cosmetic). The c5 rear calipers are slightly better because they are pressure cast aluminum rather than gravity cast like stock fbody rears. As for clearing 16" wheels the rears will but i dont think a c5 front conversion will.
the rears really arent worth swapping. 90% or more of your braking is done with the fronts. ive read many people who track or competitively road race their f-bodies upgrade the fronts, and leave the rear BONE stock, other then a pad change.
