installing suspension, encountered problem.
Right when you least expect it and also right when everything is going smooth!
I've started to become weary anytime I'm working on the car and things are moving smoothly, it's like a sign somethings bout to give!!!
LOL, I feel your pain. A simple project suddenly becomes a BS project.
Good luck and dont forget to make sure the adjustment holes are facing out where you can reach it.
!front bumper support!
!rear bumper support!
!rear seats and seat belts!
VFN pin on hood
lightweight battery
the ftra used to make a difference with little bolt ons, after a while I couldnt tell, but i'm sure it does something.
After you get the shaft of the upper ball joint through spindle, jack the lower control arm up until just about the point where the suspension is lifting the car off the jack stand on that side.
The shaft should stop spinning and you can torque the castle nut down, and put the cotter pin through and bend it.
on the passenger side i had to cut the shock in half because the mount was fused with the shock
