Prokit
Old May 29, 2009 | 07:51 PM
Quik Sand's Avatar
Default Prokit
How have they been with stock shocks? So far Ive been getting conflicting info about the prokit. If not the prokit, what springs will work alright with the stock shocks?
Old May 29, 2009 | 09:38 PM
z28bryan's Avatar
None. Stock shocks suck
If your satisfied with the prokit on stock shocks, then why change? Unless your doing some racing and could gain better results from a better shock, or just don't realize you could improve your ride quality preferences. I'm pretty sure that spring is oscillating multiple times over bumps though... with better damping shocks you can control that a lot better.
Old May 29, 2009 | 10:04 PM
Quik Sand's Avatar
well i dont have the prokit yet.....i have stock springs and shocks right now. Im just seeing how the prokit or other spring kits did with stock shocks. Thanks though.
Old May 29, 2009 | 10:38 PM
SELLSZ06's Avatar
Prokit and stock shocks here, I had this for years now. It drives good for a daily driver, dont really scrape and its pretty comfy, although i have control arms and swaybars too. It was fine for a while, but now that the car sees higher speeds and is making a lot more power I want/need something stiffer.
It depends on what type of ride you want
Old May 29, 2009 | 10:57 PM
Quik Sand's Avatar
ya my car is a dd as well. Thanks for your imput
Old May 30, 2009 | 06:47 AM
1993 z28 f1's Avatar
Hey:
Strano makes a really good riding spring, I went from Eibachs prokit to them and the only thing I don't like is the white powder coating on them.
I guess I glad I don't see them often. yellow konis with white springs
its pretty bright under a red car. A cleaning compulsive persons nightmare.
Dub
When In Doubt Do Without
Old Jun 1, 2009 | 12:27 AM
Quik Sand's Avatar
Originally Posted by 1993 z28 f1
Hey:
Dub
ya dont really care too much about the color....just about clearance issues, etc. What does it normally run to have a prokit springs put on?
Old Jun 1, 2009 | 02:54 AM
SELLSZ06's Avatar
do the install yourself, just rent the spring compressors at a auto store, its easy since these spring are shorter than stock.
Old Jun 1, 2009 | 11:39 PM
Adam86's Avatar
Subscribed... I've been pretty curious as to this too. A lot of people seem to run stockers with prokit springs but I was wondering what aftermarket shocks people have run and had good results with.
Old Jun 2, 2009 | 09:52 PM
SELLSZ06's Avatar
koni's ftmw
Old Jun 2, 2009 | 10:34 PM
LS1powered09's Avatar
replace shocks before lowering it. imo
Old Jun 2, 2009 | 11:00 PM
JDishong's Avatar
Been there with the stock shocks with the prokit.
It rode nice as long as the road was nice.
It did not like rough roads because of the limited rear travel.
Old Jun 3, 2009 | 10:04 AM
z28bryan's Avatar
..I think your rough ride had more to do with the speed you are impacting your full suspension travel and less to do with the smaller amount of suspension travel. Less suspension travel isn't ideal for ride quality no doubt, but you can't overlook the fact that stock shocks are pretty much cacca and don't slow down the speed that the spring compresses or rebounds.
In my opinion using stock shocks for any aftermarket springs is a horrible idea, fwiw
Old Jun 3, 2009 | 10:33 AM
pjb's Avatar
pjb
consider this - instead of paying $250-300 for springs, and another $350-400 for less expensive shocks (total $600-700), just get the 4/3 koni for $732 from Sam. Use the stock springs on the lower perch/rear hose mod. You'll have a great setup instead of a crappy setup that cost nearly as much.
Old Jun 3, 2009 | 11:52 PM
JDishong's Avatar
Well i'm using the bmr springs now and its much better with the added rate and a touch more ride height in the back.
Still on stock shocks.
Old Jun 4, 2009 | 01:49 AM
LCplmarine98's Avatar
Im gonna do the SLP valved Bilstiens they are valved to work with lowered springs. I already have the kit so those shocks seem like a pretty good alternative.
Old Jun 4, 2009 | 08:57 AM
z28bryan's Avatar
Angry
Like I mentioned in my first post.. satisfaction with your setup and how much your springs are dampened can be two entirely different things. If your happy then no need to change anything I guess. It's possible however, that there might be a realm of better damping that you're unaware of that you may prefer better than stock shocks.
