Does this pic show a bushing problem?
Any grease leaking out from that spot?
If it's just a defect(thick spot) in the rubber, your still good-to-go!
That's just the boot, it shouldn't have anything to do with a noise or vibration.
However, OE ball joints weren't greaseable, so I'd be surprised if the OE joints had these "bleeds" as part of the boot.
If this is a replacement ball joint, the boot should appear a little "puffier", as in "filled with grease".... If this indeed was a replacement joint, and never greased during it's lifetime, that could be part of your problem, as it's wearing faster than it should, due to lack of lube.
If there's currently a strange noise and/or vibration from that area, then I'd look closer at other suspension items around that area.
