Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- Camaro and Firebird Brake Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
- Chevrolet Camaro 2010-2015: Brake Modifications
CTS-V Brake Install w/ Pics
#782
Will do dojob. Like I mentioned earlier I have been running the 6 piston for a few weeks now. Actually did 2 days of local auto-x the last weekend with them on. Didn't notice a huge difference between the 6 piston and the 4 piston ones from before. I think the biggest difference will be the improved heat soaking ability of the new setup. Will get some miles on these new rotors and report back though.
#783
Well with my blasting cabinet and the ability to powdercoat at home I couldn't leave the calipers that dark grey color. The 6 piston calipers although look like they were low miles pull offs had were some chips in the paint and some brake fluid from the bleeder screw caused them to be a little too beat up for my taste.
Also with the darker color they were a little hard to spot behind the wheels. The white should make them pop a little more.
#785
Well I finished up with the other side caliper. The process I used was strip with aircraft stripper, then I finished up the cleaning in my blasting cabinet and finally did the two stages of powdercoating. I also put one of the wheels on to get a look at that. Still waiting on the lines from FLYNBYE. I am happy how they turned out but while test fitting the wheel of course there is like 1/4" either way so I scuffed up the top finish on one of the calipers. easy fix and I ended up applying a strip of clear bra type 3m material I had laying around to the top portions of the caliper to hopefully protect it in the future.
#790
Adding this to the thread for those provident types that actually search through threads. Did a write up and video on the conversion, sometimes seeing more of the work done can help some of us flesh things out on our own.
https://ls1tech.com/forums/suspensio...-up-video.html
#791
Well, just a heads up. I ordered the CTS-V 6 piston brake lines from FLYNBYE and he was out of fitting (this was back in August of this year). I needed the front brakes line for an event so I had EVCO (House of Hose) make me some. Fast forward to today, I just remembered I hadn't received my braked lines yet (I ordered both front and rear) had to give them a call and remind them that I have been waiting for like 4 months for these bad boys. He sounded surprised that I am waiting since Aug and said he would send them out today. I had good luck with his brake lines that I ordered back in 2010 but man that's pretty extreme. Glad I remembered or he may have never sent them out.
#792
I was considering either oem c5 17/18s and later scoring 18's for the front.
But I am also in love with OeWheels deep dish version which comes with 18's all the way around as a package.
But they specifically say they do NOT fit with Brembo or alike.
Does anyone know if that is a fact or not? Should I just stick w trying to score the oem 18s later and those will surely fit?
If you read down below it says it wont work.
https://www.ebay.com/itm/18-9-5-10-5...53.m1438.l2649
Just trying to make sure what I get allows this upgrade hopefully soon.
I read most of the thread im still trying to go through each page. If anyone out there just knows the answer. Thanks.
#797
Has anyone compared the ATS brembo 4 piston setup 1722586/7 to the CTS-V 4 piston 1722287/8 setup on their 4th gen f body? How is the pedal effort and stopping power on these compared to stock?
My front wheels are only 17x7 Race stars and will have 225/50/17 tires on them so less tire contact with the ground compared to a 245/45/17 on a 17x9.....
#799
#800
My head hurts from reading this entire thread.
I have seen somewhere a guy running his stock ws6 5 spoke 17s with this set up? obviously he had spacers.
I would like to use the stock 17s if possible, no problem running spacers as I think it would help the stance as well
So should i get the newer 2010 camaro SS rotors or the c6 z06 rotors? I have no problem machining the SS rotors bore
What length brake lines do i need?
thanks guys
thanks guys
