Koni/Strano Install Video
Nice vid!
When i did my install last month, i took both fronts out, brought them to a local garage to take the springs off and put them on the Koni's.....$25.00.
Another little trick is to make sure you mark the location of your rear springs on the axle when removing them, may avoid different heights on rear end.
I know what you mean! I stood there watched and helped alittle. Biggest thing was to make sure the front adjuster on the shock was in a place you you can get at and the spring was turned to maximize accessability.
#38
Like everyone else said, great video! I did mine back in April and have loved my new setup since! Since my car is a daily driver, I had difficulty removing the hardware for the sway bar. Wound up breaking off the bolt and had to get new ones.
Another vote to make a sticky!
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
