please explain lower perch
Old Jun 18, 2009 | 01:57 PM
redemn93's Avatar
Default please explain lower perch
where is the lower perch? anyone have a pics to tell me where i can see the lower and upper perch? i plan on doing strano bilsteins soon and want to do the lower perch and heater hose mod while i am at it.
the heater hose mod ok for daily driving? how ofter do you check yours to see if it wearing through the hose or does it not wear through?
Old Jun 18, 2009 | 03:24 PM
99Bluz28's Avatar
Lightbulb
FYI,
You can only do the lower perch with Koni SA shocks.
Old Jun 18, 2009 | 03:31 PM
JamRWS6's Avatar
As mentioned above Koni SAs have the lower perch. There are other methods of adjustable perch shocks but Bilsteins aren't one of them. The strano bilsteins are made for stock springs.
Old Jun 18, 2009 | 03:56 PM
redemn93's Avatar
gotcha. thanks.
how about the heater hose question i had?
Old Jun 18, 2009 | 04:11 PM
JamRWS6's Avatar
gotcha. thanks.
A lot of these guys say they don't have problems but I personally would be worried about wearing through as it isn't designed for that.....especially over time.
Old Jun 18, 2009 | 04:22 PM
99Bluz28's Avatar
"Hose Mod" Get about 36" of some 5/8" I.D. Oil/fuel line hose and cut it in half. Spray some Windex in each hose and on the top coil, right before sliding the hose on. Push it on until it's covering 1 full coil,and leave about 1/2" to 1" of hose extended past the end of the spring end. Then cut off the excess and reinstall the springs.
Old Jun 18, 2009 | 09:21 PM
jRaskell's Avatar
I ran the heater hose mod for over 3 years before swapping to Strano springs. There was absolutely zero discernable wear on the hose when I pulled the old springs out. If there was any rubber actually worn off, it would take decades to come close to wearing through the hose entirely.
Old Jun 19, 2009 | 09:04 AM
redemn93's Avatar
thanks guys. now i just need to measure and see if my car is actually raked enough to do it without the front ride height being able to change.
