finally an upgrade to crap factory bump stops!
#83
I think he meant the prothane part, but I'll fix your link anyway.
http://www.energysuspensionparts.com...1&stext=9.9137
#84
Sorry, but that Prothane bumpstop's to big!
What you want is Prothane part number 1-1301.
FYI, this is just like the ES Bump-Stop.
http://img.auctiva.com/imgdata/2/9/1...89768422_o.jpg
#85
Not sure if anyone is interested but when i went to do mine they were out of stock however while at the junkyard I noticed the 3rd gens used the same style bumpstops but were made out of a much harder rubber and on many cars looked new i bought a couple for a buck i think and just cleaned the grease off the brackets. They bolted right up with no mods and have been good ever since.
#87
Mine were falling apart on my 01 formula so I stopped by a local salvage yard and found that all the 4th gens there had the bump stops broken off. I decided to look at the third gens and they were all intact, so I compared the two and they mount the same. The ones used on the third gen f bodies were made from a more durable harder rubber material.
#92
I finnaly got these on my car since I got my winter wheels off today. I bought the SLP spacer one ebay for cheap since these are shorter than the stock stops. I didn't trim the spacer though I flipped it upside down. I needed a slightly longer bolts but this gave me a bit more length to the stopper.
#93
Anyone know the stock bumpstop part #? I wanna try and see if I can get stock replacements at local dealers if not I'm just gonna buy the ones Mighty Mouse got! My car is lowered and really needs new ones the stock ones are look like sh*t already!
#94
Here's a poly one with spacer:
http://www.hawksthirdgenparts.com/ca...opnewgm-1.aspx
They are a little pricey, but they do also sell their spacers separately for $55 and you can add your own bumpstops with worrying about that tab issue...
Here's a comparison to OEM w/SLP 17" Wheel spacer:
They also have poly ones with smaller spacers and other considerations like lowering w/19" wheels, etc.:
http://www.hawksthirdgenparts.com/ca...newgm-1-1.aspx
#97
these are for a jeep. they were cheap and they bolted right up!
since i am trying to keep my midwest rear end from beating up my gas tank, i had to do a little work to the slp bump stop spacer to re-use that.
check it out!
factory stops are GROSS!
making the spacer work (do not need if the car didnt allready have them)
beautiful!
real excited about that one.. man i hated those factory stops!
check it out!
beautiful!
