Which Bilsteins??
Old Jun 23, 2009 | 10:02 PM
nomadfenix's Avatar
Default Which Bilsteins??
Finally shedding the crappy Decarbons....I've driven an f body with the Bilsteins and want them....The question is, which set? I have BMR springs [the old ones]....Any recommendations? Thanks.
Old Jun 23, 2009 | 10:20 PM
wannafbody's Avatar
Either get Strano spec Bilsteins or 3rd gen rear Koni's. I recently bought 3rd gen rear koni's and they are a vast improvement over the standard HD rear Bilsteins.
Old Jun 23, 2009 | 11:02 PM
goldmecham's Avatar
get the rear bilsteins for a 82-92 it has the better valving then the 93+
Old Jun 23, 2009 | 11:13 PM
LCplmarine98's Avatar
Go with the SLP valving its meant for lowered vehicles
Old Jun 24, 2009 | 11:51 AM
Arc00TA's Avatar
I have the SLP bilstiens on stock springs and they work pretty well. Once they wear out I'll be getting konis though.
Old Jun 24, 2009 | 12:37 PM
z28bryan's Avatar
SLP's shocks were originally meant to go with their SLP springs (by SLP). Sam had mentioned SLP shock part numbers are identical to the HDs. Bilstien even states HDs are underdampened for lowering springs.
Old Jun 24, 2009 | 01:05 PM
JamRWS6's Avatar
Not to mention the SLP springs aren't that much of a lowering spring.
Old Jun 24, 2009 | 01:06 PM
99Bluz28's Avatar
I believe it's just the rear shocks that are the same, not the fronts.
Old Jun 24, 2009 | 01:39 PM
z28bryan's Avatar
Ooops. My bad.
Old Jul 4, 2009 | 10:40 PM
Dom's Avatar
Dom
What kind of springs rates are SLP Bilsteins meant for?
Old Jul 4, 2009 | 10:47 PM
wannafbody's Avatar
300-400 range for the fronts.
Old Jul 5, 2009 | 01:20 AM
99Bluz28's Avatar
I beleive it's up to 450 for the fronts.
Old Jul 5, 2009 | 06:13 AM
kennerz's Avatar
I have the factory SLP Bilstiens/SLP Eibach springs. THe ride is nice and it handles well. a few years back I upgraded to the Koni SA's, and the 3rd gen rears. No comparison. They ride slightly harsh, but the dampening quality of the koni's is far superior to the BIlstiens.
The cars limits increased dramatically, it is much more stable at high speed, and the overall control is much better with the Koni's - they are easily worth twice as much IMHO. If you want a silky smooth, buttery ride - get the Bilstiens. Otherwise don't be a fool, buy the Koni's - they're that much better.
Old Jul 5, 2009 | 07:54 AM
z28bryan's Avatar
Out of curiousity, is that limit claimed by SLP?
Old Jul 6, 2009 | 01:38 AM
RevGTO's Avatar
Pontiacerator
I couldn't agree more ... if you want to crash hard into every sharp bump - get Konis. Yep, they handle better at the extremities ... but you'll pay the price in everyday comfort.
Old Jul 6, 2009 | 02:10 PM
99Bluz28's Avatar
Lightbulb
No, but considering that the springs they're designed to go with have about a 450 lb./in. spring rate up front I would assume that they would have the shock valving designed to handle that spring rate.
Yeah, I know, I committed the high crime of assuming.
Old Jul 7, 2009 | 10:46 AM
Sam Strano's Avatar
LS1TECH Sponsor
To be fair, that's a very, very minority opinion and has lot to do with other things like ride height and you know, where the shocks are actually set damping wise.
Not saying that Koni's might not be too firm for some like RevGTO, but overall 95% of the feedback isn't in agreement--in fact most find Koni's to ride better than stock, or other cheaper shocks where other things like stupid springs and so on aren't interfering.
__________________
Old Jul 7, 2009 | 09:26 PM
RevGTO's Avatar
Pontiacerator
I upgraded to the Koni SA's ... They ride slightly harsh, but the dampening quality of the koni's is far superior to the BIlstiens. If you want a silky smooth, buttery ride - get the Bilstiens.
I'm seconding his experience that Bilsteins offer a smoother ride; Konis are harsher. This is a point that's been made by many guys on this forum. For most on this board, the increased dampening capability of the Konis makes it worth it. But there is a trade-off, and people should be aware of it. Reading this forum indicates a significant percentage of Koni purchasers are surprised to discover this after they've installed them.
Old Jul 8, 2009 | 09:25 AM
z28bryan's Avatar
Lets use some logic and reasoning to come to some sort of conclusion to this...
Let me ask this.. is the compression on Koni SA's any stiffer than Bilstien HD's front/rear? If it's about the same, then I'll argue that Bilstiens can only be as comfortable or more comfortable shock than the Bilstiens.
In the end.. ride comfort is all personal taste. Though if something has the range of adjustment that covers a wide range of adjustment of rebound when the compression is fine, then I'd like to make the arguement that the range puts the shock's potential in one's good ride comfort zone. aka making it a more comfortable shock. My guess is half of the people here who said Konis ride was uncomfortable didn't take the time to tune them.
Some shocks move like crap in the tube. Like STI stock shocks in my 05 I used to have. They felt like the car was always trying to break the piston free of being stuck. This can also be a big factor in ride comfort. I'm assuming Bilstiens are the complete opposite of this due to their great build quality.
Old Jul 8, 2009 | 10:53 AM
JamRWS6's Avatar
My guess is those people were subscribing to the 'stiffer is better' magazine rather than tuning the shocks and making them softer for a more compliant ride.
As far as Koni vs Bilstein compression I would be interested to hear as well. My guess is the Konis have more compression firmness, though.
