Lowering the front only? Couple Q's..
I'm looking into lowering the front of my car only, I really like the stance in the back with the heater hose mod, but not the front since it actually sits higher than the back and has wheel wells that could hide hondas. Here is my current setup:
SLP bilstiens all 4
Stock WS6 springs
Heater hose mod in the back
Now, I'm thinking BMR springs since I have heard good things about them, and they sell only front and back pairs as well as full sets. The drop is exactly what I am looking for as well. How would the car handle with only front lowering springs? Should I just put my isolator back in and run a full matched set, as this would probably keep me at the same height in the back?
Also, moving onto the shocks, would they work ok with the BMRs? I don't have the budget right now for koni's, but I am also interested in getting some of the "slam" out of the rear end when I hit a bump, the front feels good but the back it bone jarring. So maybe a different rear shock if the fronts would be ok? What would you guy suggest?
SLP bilstiens all 4
Stock WS6 springs
SLP bilstiens all 4
Stock WS6 springs
SLP bilstiens all 4
Stock WS6 springs
My guess on your rearend is the SLP bilsteins, the valving isn't much different than the stock deCarbons.
Your ride will probably be OK at first on the Bilsteins, but will most likely deteriorate as the shocks wear.
LS1Tech Premium Sponsor
You can do fronts only. You would be better off putting your isolator back in and running both front and rears. The bilstiens will work ok till you can upgrade to a better shock. I have the springs in stock and ready to ship.Give me a call if you have any questions.
Originally Posted by JamRWS6
Your car is going to look really weird with that drop only in the front. I'd suggest just switching back to the isolators in the rear and running a full set of lowering springs of your choice.
UMI Performance!
Hello
Another suggestion you can do is go with the heater hose mod in the rear. And then go with a coil over on the front (depending on what you use the vehicle the most for depends on the spring rate) but you will be able to set the ride height to your personal preference. And not only that as long as you get a good shock in the rear you will transfer weight a lot better as well. Below is a link to show you what UMI Performance has to offer!
http://www.umiperformance.com/catalo...0c7gvpo1vvmtq3
If you have any other questions feel free to ask and I will be more than glad to help!
Thanks
Brad
Thanks
Brad
