Alignment after lowering?
I hope I don't need another alignment. I literally just got it done Friday. I'm hoping nothing happens. The only thing I'm worried about is taking the spindle off the upper control arm. I don't think anything should get funked up on that part. I just had the entire front end off last weekend so I'll be pretty pissed if I need another one. But thanks for the info! Anybody else?
I was actually thinking about that. Probably going to do that.
I just lowered mine and it needs to be re-aligned. The steering is just fine but you can see how the camber is off. Im waiting till I get my Koni's put on before I have it done though. I have Stranos with stock shocks on now.
The product of additional negative camber, though, is toe setting changes. As you change camber, toe moves. Adding negative camber results in more toe in.
Well a good amount of my buddies work there. So I think they're gonna just hook it up for me. Well see when I go. I'm gonna try and go when the same tech isn't there so someone else will do it and probably won't notice.
