how much for lowering kit install!!??
Old Nov 20, 2003 | 11:30 PM
franny40's Avatar
Default how much for lowering kit install!!??
I am thinking of ordering a lowering kit compromised of lowering springs, adj. panhard rod and LCA reloc. brackets, so I called some shops for some install prices, I was quoted 400-450 dollars, Does this sound right or am i getting duped
Old Nov 20, 2003 | 11:51 PM
camss69's Avatar
Let me know what you find, I'm in NorCal too..... the Sacramento area.... I'm probably going to have this done in the next couple months, I'm thinking of going to a shop in Roseville but dunno how much they are going to charge me yet....
Old Nov 21, 2003 | 07:48 AM
mitchntx's Avatar
It's a solid 4 or 5 hours of work worth of work to install springs, APHB and LCA relocation brackets.
So, ask what the shop rate is and do the math.
Old Nov 21, 2003 | 08:21 AM
jimmyblue's Avatar
Moderator
The only thing you need more than hand tools and
a pair of jackstands for, are the fronts. The best deal
may be to just get that done, with a front end align-to-
order as part of the deal if it's more than a 1" drop, at
a shop and do the rest on the driveway. Paying shop
rates for rear suspension work is not such a good deal.
Old Nov 21, 2003 | 05:13 PM
mcflyz28's Avatar
rent a spring compressor and do it yourself, use the money you would have spent on a shop for better shocks !!!
Old Nov 21, 2003 | 05:37 PM
franny40's Avatar
Thanks for all your responses fellas, but I have a co worker who has installed his own springs,TC,cam and so on and he said if I am not afraid of getting dirty he will help me. So I think I am going to go the DIY route. I am excited about doing my own work and gaing some knowledge.
Old Nov 21, 2003 | 06:23 PM
jimmyblue's Avatar
Moderator
In the Chevy High Performance I got today they went
and took out the struts, and went to some auto parts
place to get the springs off & on. Of course this doesn't
work if you don't have a ride... but this is a zero-shop-
rates alternative.
Old Nov 21, 2003 | 07:39 PM
mitchntx's Avatar
DYI is the best way.
Go slow, take your time and double check everything.
