lowered car/ panhard bar????
car was lowered in the front about 1.5" and in the rear was dropped 1.2" I believe which was a bmr rear spring. Either way with the vehicle being lowered will I need to have a panhard bar relocation kit installed on the car and if so which one to get, what exactly will it help with??
thanks, Tom
thanks, Tom
It also provides other benefits as mentioned as well. The difference isn't huge but why lower if you aren't going to do it right?
Well I made my own double adjustable phb and saw no difference. I drove about 8000 miles with the car lowered on the stock one and when I took it off it still looked new. Now I can see where it might be important at the track but I don’t think its that necessary. If you have the money then go ahead.
Hello
I always think of it this way! It's always a good idea to have a adjustable PHB (rod end version) just because if you want to run a bigger tire and need to center the rear or it also eliminates any binding issue that you might have with the rear end! I just figured I would through in my opinion! Below is a link to show you what UMI Performance has to offer!
http://www.umiperformance.com/catalo...qiliqlbenh5677
If you have any other questions feel free to ask and I will be more than glad to help.
Thanks
Brad
Thanks
Brad
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
How would it be doing the wrong way? I notice no differnce when I had the stock phb and then went to adjustable phb. In that case everyone who gets lowering springs should by shocks, lcas, and adjustable a-arms.
did you adjust the PHB to recenter the rear end? if not you should have, if you did then you corrected problems you weren't even aware you had.
and yes, when you go to lowering springs you should change shocks (assuming you are on stockers), the rest is not essential.
LS1Tech Premium Sponsor
thanks, Tom
thanks, Tom
http://www.bmrfabrication.com/F4.htm
I put over 8000 miles on the car before I put double adjustable phb and lcas on my car. They looked brand new when I took them off, no wear on the bushing. So you tell me how much binding is acceptable.
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
Im not sure where your getting your info but I don't see how LCAs or adjustable A-arms are in any way necessary, or even recommended, when lowered.
To lower the car properly you do need an adjustble PHB, and shocks that can damp the springs. Even though my rear end was sitting noticeably uneven after lowering with a stock PHB, the aftermarket adjustable PHB did nothing performance-wise for me as far as I could tell, but did recenter the rear. Shocks on the other hand are a HUGE improvement, and anyone driving around on stock shocks are REALLY missing out.
