brakes
Old Aug 11, 2009 | 02:08 PM
00TAM6's Avatar
Default brakes
Does anyone know what is the minimum thickness on front and rear rotors for my 2000 ta? im trynna save some money and not get new rotors when i dont need them. thanks
Old Aug 11, 2009 | 02:53 PM
BlackScreaminMachine's Avatar
Internet Mechanic
To do it right, you need to have them cut. If there are any minor imperfections, you can HOPE the rotor trues up but stock GM rotors warp like no other so cutting does really help, often buying new is the solution.
Old Aug 11, 2009 | 05:27 PM
02 35thLE's Avatar
Front discard thickness 30.7 mm or 1.209 in and rear discard thickness 24.51 mm or 0.965 in.
Old Aug 11, 2009 | 07:01 PM
00TAM6's Avatar
Thanks bro.
Old Apr 16, 2012 | 08:07 AM
Vetal's Avatar
What happens if my front rotor was cut below 30.7mm? Is it dangerous?
Old Apr 16, 2012 | 01:08 PM
Internet Mechanic
Wow talk bout a dead thread.
Now almost 2 years later. I would call a dealer for specs or tolerence. Should be able to help you.
Old Apr 16, 2012 | 04:01 PM
Vetal's Avatar
That's called "Search"
I just wonder what happens if I go below minimum - is it matter of rotor warping too easy if it gets in water while hot?
Or is it matter of brake pistons going out too far, beyond their limit?
Old Apr 24, 2012 | 08:37 AM
Internet Mechanic
Yea, I posted on this like 2 years ago, which is what was referenced and your better off making a new post... as much as search works, not everyone is going to jump back in
