Can someone ID this Brembo caliper and rotor
Yes I only have one,(dont ask) and got it with a BBS 18 inch wheel. No one knows what it came off of.
Looks like a 114MM 5 lug bolt pattern.
Rotor is a huge 14 inch,caliper is a 4 piston.
Rotor has a floating hat(2 piece design).
Would like to find out what it is and see if :
A. I can buy 2 hats,one rotor and caliper and adapt to one of my F bodys
B.sell it if its too costly to do A.
In order to do either I need to ID it first.
Rotor has absolutely no wear and caliper is only a little dirty.
Could be but EVOs used 1 piece rotors
these are clearly aftermarket
any ideas?
BTW I measured the rotor again and it was 13.8
doesnt look like this combo will fit under my 10 spoke 17s,
may need to use a smaller rotor.Ive got some C-6 ones,perhaps those will work.
any ideas?
Yeah Evo's came with 1 piece rotors but seeing how expensive brakes are for Evo's and STI's, most people go aftermarket. Especially the people that track their cars, they typically transition to 2 piece rotors before doing a caliper swap, at least from what I've seen and read.
Did the BBS wheel look like this?
