which car handles better?
i was just curious because my dad owns a mach1 and it seems to handle pretty good
my z28 feels pretty good with the stock springs, kyb 8 way adjustable shocks/struts, and SFCs, but if u push it too hard around corners, youll know it. my friend had a 98 cobra with a steeda adj suspension, that thing felt frickin sweet
But ...
That slip-angle can cause problems, though. If you run out of talent, the rear will swap ends with the front. So you have to be patient in getting on the throttle.
Similarly, because the F-Car has a longer wheel base, it doesn't turn-in quite as crisp. It will plow through the turns if the driver tries to power into a corner.
So, saying one "out-handles" the other is extremely simplified. Its more about the driver than it is the platform.
