Cheap front lowering mod?
Old Oct 13, 2009 | 10:28 PM
00RedMaro's Avatar
Default Cheap front lowering mod?
I have heard that there is a cheap front lowering mod that you can do in correspondence with the rear heater hose mod to lower both ends of your car? Is there such a mod? And if so does someone have a link? This would be perfect for my V6 so I dont have to throw down money to get it lowered, since I'll be getting an SS in a year or 2.
Old Oct 13, 2009 | 10:59 PM
zach_ws6's Avatar
there is nothing as easy as removing the isolator in the rear.
you can cut 1 coil out and that would lower the car about an inch.
Old Oct 13, 2009 | 11:27 PM
00RedMaro's Avatar
what exactly do you mean by cut one coil out? sorry i am new to the suspension side of things.
Old Oct 14, 2009 | 01:09 AM
mediocrels1's Avatar
cut the spring.
do the heater hose in the rear and cut the spring in the front
Old Oct 14, 2009 | 05:05 AM
Major_Lee_Slow's Avatar
Do not cut the coil springs, the results are hardly worth the effort. Springs are not that expensive, you'll be much happier if you save up your pennies and buy the right aftermarket spring. Bellow is the mathematical reason why cutting springs is not a good idea. I first posted this in this thread
Originally Posted by Major_Lee_Slow
Jimmy you are right. By removing coils the spring rate does increase, but not by that much. The equation for calculating spring rate is:
K=(Gd^4)/(8nD^3)
G = material rigidity or torsional modulus
d = wire diameter
n = number of coils
D = mean coil diameter
Now when we solve for K of our cut springs, G, d, and D are constant. So we can rearrange the equation to state:
(Gd^4)/(8D^3)=k1n1=k2n2
therefore we can solve for k2
k2=k1*(n1/n2)
So if we were to cut one coil from my 1LE springs, we can calculate the new k2
N1=9 and K1=342lb/in
so k2=342(9/8) = 384.75.
The rear Z28 springs are 113 in lbs.
N1=9 and K1=113 lb/in
If we cut one coil from them:
k2= 127 inch lbs.
So the OP experienced a 2 inch drop when he cut his springs. Now he's asking the springs to absorb the same amount of load in a shorter distance with only a minimal increase in spring rate. The ride feels "pretty rough" because he's probably getting into the jounce bumpers in the front pretty often which, BTW, have an extremely high spring rate vs. the coil springs.
Note most aftermarket spring kits are in the 500-600 lb/in (front)and 150-175 lb/in (rear) range. They have to be or else the car gets into the jounce bumpers way too often.
Argument settled. Thank you, now please move on and go buy a decent set of springs.
Old Oct 14, 2009 | 10:42 AM
faster_n_you98's Avatar
is cutting springs the BEST way to lower your car? No.
is it cheap and efficient and what the original poster was looking for....Yes
I have had mine cut for well over a year and have no issues at all.
Old Oct 15, 2009 | 01:14 AM
ta da. the OPs objective is to enhance visuals. hes got plans for an ss...i think cutting the front and heater hose - ing the rear "fits the bill" as they say.
Old Oct 15, 2009 | 08:40 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Hello, we have a 1.25" front lowering spring with a front spring rate of 550lbs. I can sell you just the fronts if thats all you want. This is a much better choice than cutting off a coil. Give me a call for pricing.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
