Relocation brackets needed or not?
Old Dec 5, 2003 | 04:40 PM
ssdungeon's Avatar
Default Relocation brackets needed or not?
I just ordered LCAs and SFCs they are to be installed next week hopefully. Will I need relocation Brackets? I dont understand what they are used for. My car is not lowered. I just need traction. The LCAs are the G2s.
Thanks,
Old Dec 5, 2003 | 05:17 PM
sunsetz28's Avatar
I believe you only need them when you lower your car to correct the angle of the LCAs.
Old Dec 5, 2003 | 05:22 PM
ssdungeon's Avatar
I appologize for not understanding... Can the LCAs be installed without them.
Better question is "Will I only need them if I am lowering the car?" I plan on lowering the car at a later time for now I only need to get traction.
Old Dec 5, 2003 | 05:28 PM
sunsetz28's Avatar
Yes I believe that is correct. You will need them when you lower your car, but not otherwise.
Old Dec 5, 2003 | 05:31 PM
ssdungeon's Avatar
Thanks I was making sure I had everything before I got to the shop.
Old Dec 6, 2003 | 06:49 AM
smokin' joe 00 ss's Avatar
The lowering bracket's will help with traction on a non lowered car, I run my LCA's in the bottom bolt hole of the lowering bracket's and that help's alot when launching the car.
Old Dec 6, 2003 | 03:47 PM
glitch77's Avatar
Like Joe said, they will help ANY cars traction, lowered or not.
I have a 1.5" drop on my car, and have no brackets and didnt notice any change for the worse.
Old Dec 6, 2003 | 09:26 PM
ssdungeon's Avatar
Well let me find some if I find them for the right price why not getem'
Thanks guys.
Man I love this forum
Old Dec 8, 2003 | 04:35 AM
98_1LE's Avatar
I do not have the relocation brackets, and have had the Pro-kit and G2 springs on my car with no ill effects. The car hooks up well with no wheel hop.
Old Dec 8, 2003 | 09:36 AM
I'm not saying anything about ill effects, I've run my car with and with out and it comes out of the hole way better with them than with out them. If you tried them I'm pretty sure your statement on the car hooks up well would change.
Old Dec 8, 2003 | 01:26 PM
jimmyblue's Avatar
Moderator
With that much LCA angle bias on stock height, did you pick up any
rear brake hop?
Old Dec 8, 2003 | 02:24 PM
I can hammer a 80 MPH to 0 braking and won't get any rear hop at all.
