Need suspension advice
No need to be an ***, you're the one who asked for advice...I was making a point based on my hard learned lesson and sharing it with you.
Fact is, Bilsteins are a stock replacement shock - they just happen to do EVERYTHING better than the POS de Crapons. They will also last MUCH longer than the QA1s, which are not good quality pieces. The fact also is, you can have your cake and eat it too if you play your cards right. If you want to drop coin, go with the Afcos, which are quality like the Konis, but more for drag applications. Finally, there are numerous folks with Konis and Bilsteins cutting 1.6 short times, and better.
I don't care what you want to do with the car, shocks should be first, they are the worst part of the car.
^ I want a 1.40 sixty which a drag shock can get me there. no offense, was being an ***, I was just saying in the last post. I was looking for something that makes my car handle better, just something that helps me get that 60ft better.
Just seem like your were being an before that, my bad if i took it wrong.
