Should I bend my spindle back straight?
I hit a curb on my front drivers side. Busted the steering rack and replaced it. Took it for an alignment and they cannot get anything better than +1.5deg camber. I took apart both sides and the left spindle is bent about 2". My friends suggest bending it back insteady of buying a used one from a junk yard that might be bent, too. I can probably have it done at the machine shop at my work.
Any comments or advice?
LS1TECH & Trucks Sponsor
I would recommend replacing it.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
definitely replace. you can take your old one to the junk yard, and/or call around the junk yards and find a junk yard that has multiple spindles. you can line them all up on a table and see which are the least bent if any of them are. if you use your current bent spindle for comparison, it should be relatively easy to find a good one. the v6 f-body uses the same spindle, so any spindle that works is the same spindle you bent.
in dallas i have found spindles ranging in the price of $30 to $150 for a used one. gmpartsdirect lists a new one at $200, so if you can't find a used one less than $100, just buy a new one.
