Subframes...
Old Jan 6, 2010 | 04:44 PM
lswon80's Avatar
Default Subframes...
I am torn between UMI performance and BMR when it comes to these.. I watched UMI's video on their site showing their shop and how everything is american made which was a good selling point.. Then I found a post on here stating that BMRs fabrication of the part is one piece rather then two pieces welded together.. I have the pictures listed below.. Which would you rather have?? or can anyone tell me y or y not would be good.. However Im pretty confident that both companys make a terrific product Im just asking opinions???
BMR http://www.bmrfabrication.com/F-bodyChassis.htm
UMI http://www.umiperformance.com/catalo...roducts_id=191
Old Jan 7, 2010 | 11:24 AM
UMI Performance's Avatar
Hello,
Thanks for the interest in our product.
And you are correct, both companies make great products and you can't go wrong with either. I think the piece you are referring to is where the SFC mounts to the rear control arm. BMR cuts there bracket from one piece and bends it while we machine ours and weld it together. I don't think either is a bad design or would fail on you.. its just simply a manufacture preference.
As you mentioned all our products are built in the USA and 99.9% of them are made right here in our Pennsylvania facility. Our Facebook page has over a 100 shop pictures showing some steps of production and our equipment. Please take a look and let me know if you have any questions.
http://www.facebook.com/?ref=home#/p...1448642?ref=ts
Thank you!
Ryan
Old Jan 7, 2010 | 12:30 PM
JeaneZ28's Avatar
They're pretty much the same thing. Just go with which one you can find cheaper.
Old Jan 7, 2010 | 01:51 PM
Sam Strano's Avatar
LS1TECH Sponsor
Well... first of all if you want a 3-point SFC, BMR does not make that which means that's not an option.
Seems you are ok with 2 points, and that's fine... they aren't as stiff as they don't triangulate to 3 points, and if you ever go with a tunnel mount TA you'd definitely want 3's over 2's to distribute the torque loads into the SFC and not the floorpan.
As for which is better. Functionally if you use the same design they are the same. I like UMI. I sell their stuff, work with them, have them make some things for me, and trust them.
__________________
Old Jan 7, 2010 | 02:11 PM
ThoR294's Avatar
2 point SFCs + Torque Arm Relocation = bad?
Old Jan 7, 2010 | 02:14 PM
Sam Strano's Avatar
LS1TECH Sponsor
A TA relocation bracket is very different from a Tunnel mounted TA. No, a TA Relocation + 2 pts does not = bad. A Tunnel mount TA + no or only 2 pt SFC's = not good as the torque load goes into the floorpan (sheetmetal only) and can rip it up. 3 pts take the load..
__________________
Old Jan 7, 2010 | 02:18 PM
ThoR294's Avatar
I just answered my own question... UMI sells a kit that has the Adj Torque arm WITH the "tunnel mounting" kit. but they ALSO sell a torque arm "relocation" kit. So, I assume I should get the ADJ torque arm then get the relocation kit, seeing that I have welded in 2 point BMR SFCs?
Sorry for the thread hijack btw
Old Jan 7, 2010 | 04:15 PM
lswon80's Avatar
Interesting stuff Thanks guys.. Info well needed Tax time is comming...
Old Jan 7, 2010 | 04:55 PM
teke184's Avatar
i'm very happy with all my BMR stuff.
they've always had great customer service.
never used UMI....i'm sure they are great as well.
Old Jan 7, 2010 | 09:57 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Three point system with the tunnel brace tying the two together AND mounts the torque arm AND has the drive shaft safety loop. Looking at the websites, only UMI has all the stuff needed. If you're gonna do it, do it all the way.
Old Jan 7, 2010 | 10:56 PM
ThoR294's Avatar
I was thinking about getting that torque arm kit... but after reading what Sam said... I guess i cant cause i have welded in 2 point SFCs
Old Jan 8, 2010 | 11:14 AM
nj85z28's Avatar
alot of good info here..was going to ask a similar question..thanks!
Old Jan 9, 2010 | 07:03 PM
99TransAmLS16Spd's Avatar
Sam only said that it's not as good to go that route. But as long as your floor boards are in good condition, i.e. no rust then you are fine for the power level listed in your sig.
Ideally you want the 3 point for this but it is not necessary.
Old Jan 10, 2010 | 03:14 AM
ThoR294's Avatar
Ill have to check my undercarriage i guess... haha. but i assume if i get the tunnel mounted, I would need A LOT of power to do any damage under the car... Im just a worry wart. Is there a big advantage to get the tunnel mounted vs. the relocation crossmember for the T/A?
Old Jan 10, 2010 | 12:19 PM
teke184's Avatar
tunnel mount is generally better for drag racing
