Getting lower with Strano/koni Setup
Old May 5, 2010 | 07:11 PM
  #61
hiltsy855's Avatar
Originally Posted by 01Blk*SS*
....So did you have the koni/strano setup on the car before and after you did the UMM? lower perch? and if so how much did it lower your car?
The primary reason for doing the UMM in the first place was to gain shock travel when putting the Stranos on the lower perch, so I did it all at the same time. I had it apart several times so I don't recall the exact amount of drop (going to the lower perch) but it was in the 1/2" - 5/8" range.
Old May 5, 2010 | 07:14 PM
  #62
hiltsy855's Avatar
99 - That's an awesome spring/shock setup. What spring rate are you using now?
Old May 5, 2010 | 11:40 PM
  #63
99Bluz28's Avatar
Hypercoils with a 625 lb.in. spring rate.
Old May 8, 2010 | 01:17 AM
  #64
01Blk*SS*'s Avatar
Do the spring rates mean it takes "625 lbs to compress the spring 1 inch?
Old May 8, 2010 | 06:39 AM
  #65
leadfoot4's Avatar
Yes.....
Old Sep 1, 2010 | 12:13 AM
  #66
Fire-formula 93's Avatar
Anyone tried the UMM, strano, koni on lower perch combo yet? Need reviews my stranos are on the way!!
Old Sep 1, 2010 | 12:21 AM
  #67
01Blk*SS*'s Avatar
I would like to know also, I havent had time to do the UMM
Old Sep 1, 2010 | 12:31 AM
  #68
Seems feasible, curious to see if decent alignment specs are achievable too. If so, I'm all for it! I want it to be LOW but I want to do it right
Old Sep 1, 2010 | 09:38 AM
  #69
ls1pepito's Avatar
subscribing
Old Sep 29, 2010 | 11:25 PM
  #70
01Blk*SS*'s Avatar
have you done the mod? review?
Old Sep 30, 2010 | 12:00 AM
  #71
Decided not to do the mod and just use the upper perch with the stranos. I am actually very very happy with the drop, ride, and handling. I feel like a kinda pussied out a little but if I had a chance to do it all over, I'd do it the same way. It looks phenomenal in person and has the perfect stance in my opinion. Very slight rake with the rear isolators still in place, that's exactly the way I wanted it.
It's really amazing how these cars in pictures just dont do justice to the stance. I have looked at strano dropped cars in pics for years and said to myself, thats just not quite low enough, but in person, it's absolutely perfect
Old Sep 30, 2010 | 07:34 PM
  #72
01Blk*SS*'s Avatar
thats kinda how I ended up, do you have any pics of before and after? im curious what your final drop in inches was.
Old Oct 1, 2010 | 11:45 PM
  #73
Chrismikeb's Avatar
im curious whats the distance between the center of your center cap to the top of the wheel well? front and rear?
Old Apr 15, 2011 | 12:02 PM
  #74
01Blk*SS*'s Avatar
front and rear are all about 14.5"...
