K Member + Daily Driver??
Moderator
For a trailered car, use whatever you want.
For a car that might just see a weld fail a few hundred
miles from home (or said trailer), you want to be a little
more particular about how the piece is built.
Nobody guarantees nuthin', when it comes to performance
suspension parts on the street, so it's all on you - no
matter what the marketing happy-talk.
I daily long distance drive with a UMI road race and custom HTP solid motor mounts. No complaints compared to factory, only feels much more solid. Did the upper and lower arms as well and I like it. Hard to directly tell you why I like it but I do, and its lighter- Cause The OP and I were thinkin similar - shed weight.
I've never heard of someone having a failed weld or their tubular suspension becoming brittle. Not saying it couldn't happen but I'd imagine these companies wouldn't be in business long if motors are falling through..lol.
its been said a million times already, but everyone's lower a-arms shock mount design seems to bend, but UMI redesigned it so it is pretty much bullet proof. When I had mine bent, UMI promtly fixed it.
#32
Hello
No matter who you talk to they have there own opinion about certain companies. But One thing about UMI Performance if there is a problem with one of our products and as long as it is within the 2 year warranty we stand behind our products 100%. Before we offer anything to our customers our products go through a extensive amount of testing on our own personal vehicles. If anyone has any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
#33
A lightweight aftermarket K-member that isn't as structurally sound as the stock k-member seems like a little bit of overkill for a daily driver.. but that's just me. I've seen some people who have gutted stripped interiors and say it's their grocery getter
#34
Hard to say, I want to drop weight but keep all the interior panels, I don't want the car to look like garbage. There is the thing though, how much weight do the varying brands drop vs. complaints of breakage? They should be able to make it structurally sound. I've got to drop some weight for that iron block I'm dragging around. Less weight, better handling/braking correct? Slightly probably un-noticeable drop in fuel consumption with less weight? Less wear and tear? I want all the above.
#36
k member
I recently bought a Camaro with a BMR K member and control arms and so far so good... Daily driven and sometimes abused.
Roads around here are crap too. Car is nice and solid.
Seems real nice!
#37
BMR K-members are backed by our 2 year warranty to be free from defects in material and workmanship.
We also offer the widest variety of K-members for every application....
#38
When I bought my tubular K member from AJE, I asked him which I should go with he said if you drive your car on the street mild steel, it isn't as prone to breaking because of the various conditions of the roads, if you hit a pot hole hard or a solid road titty something in the K member is going to be toast. I have run both and never had a problem cracking, but my next K member will be mild steel again.
#39
