LCA clunk...
New bushings? I don't think it's because they need grease...maybe they're over-greased? The nipples were pretty much caked with grease and it's greasy all around the bushings and what not. Just trying to figure out what the best option is. I could install the stock ones to actually make sure it's the LCAs, but I just put Koni/Strano setup on so I know it's not the shocks.
Thanks in advance for the help guys. Don't really have the money at the moment to get new LCAs so that's out of the question right now.
Seeing how you mentioned that there is grease everywhere. Then I would say it sounds like the the bushings are blown due to being over greased. I would suggest seeing who makes them and see if you can get replacement bushings.
Hope that helps
Brad
Maybe it is a good thing I don't have aftermarket LCAs yet
Take it easy,
Brad
How often do you grease them typically? Just when new and that's it, or at certain mileage intervals, or ?
