need to gain some ground clearance
I feel like my car is TOO low even from a performance stand point. I want to come up just about half an inch on all four corners and plan to accomplish this with rubber spacers. In the rear I could install a rubber perch at the top of the spring, but at the front I dont know how to accomplish what im after, any suggestions would be appreciated. Thanks
you can use spacers in the front as suggested above, but if you're willing to raise the height I'd say it's a good idea to take advantage of the extra shock travel at the same time. also listing mods will get a more useful answer.
Change the springs.. What ones do you have? That might help to know that. Either your springs are too low, or you might have a structural problem. I'd guess you probably have low crappy springs. Springs don't cost too much.. and you'll get a better result that way than adding padding and keeping the same suspension travel.
