high speed problem plz help
Old Jul 8, 2010 | 01:09 AM
atkinsson's Avatar
Default high speed problem plz help
so my car drives smooth and all but when I get to like 130mph my shifter starts vibrating and can feel vibrating from shifter back to rear end I wanna know ways to keep everything stady even at 160mph so any things I should look for ? And y do you think it does that at high speed? My drivshaft is stock but I don't think that's the problem
Old Jul 8, 2010 | 06:37 AM
leadfoot4's Avatar
If your driveshaft is stock, that most likely is the problem. Beyond that, I'm not saying a thing. I'm assuming, maybe incorrectly, that you're trying to go that fast on a public road.....
Old Jul 8, 2010 | 07:36 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
It's definitely your driveshaft. Most OE driveshafts are rarely smooth past 120mph. A larger diameter, well-balanced shaft will have a much higher critical speed and generate fewer harmonics...
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jul 8, 2010 | 12:03 PM
atkinsson's Avatar
ya stock ds so ill replac it see if that works any drive shaft recomended tht will exceed top speed?
Old Jul 8, 2010 | 01:38 PM
leadfoot4's Avatar
Try an aluminum shaft from Lingenfelter....
Old Jul 8, 2010 | 02:12 PM
atkinsson's Avatar
okay the drive shaft I alredy got is aluminim but I'll give them a call see what's up and give them a call lingenfelter thankx
Old Jul 8, 2010 | 02:37 PM
XtremeDime's Avatar
Just because you have the stock aluminum DS doesnt mean you wouldnt benefit from a different aluminum DS that is designed for performance applications.
Old Jul 8, 2010 | 03:14 PM
libertyforall1776's Avatar
Or try a Carbon Fiber one (supposedly the ultimate):
http://www.acpt.com/driveshaft/index.html
Old Jul 8, 2010 | 07:38 PM
MasterTomos's Avatar
you could also talk with PST (precision shaft technologies), i've heard great things about their products as well.
Old Jul 8, 2010 | 09:15 PM
SS SLP2's Avatar
how about your trans mount, OE or after market? if you need a new shaft you may like to talk to Bob
https://www.brutespeed.com/index.htm
good luck, Johnny
