I need traction !!!!!!!!!!!!
Old Jan 25, 2004 | 06:11 AM
greekss's Avatar
Default I need traction !!!!!!!!!!!!
I basically have a stock car... but ill be puttin in a cam soon and as it is when i punch it in first the rear hops all over the place lord knows how bad it will be with the extra hp ... what cures this ??? and what would u recomend for better traction/hook up ???
Old Jan 25, 2004 | 09:59 AM
mcflyz28's Avatar
LCA relocation brackets.
Old Jan 25, 2004 | 10:51 AM
2_wacko's Avatar
LCA Relocatons Brackets and maybe some LCA's.
Old Jan 25, 2004 | 02:39 PM
greekss's Avatar
r these pretty easy to install ?
Old Jan 25, 2004 | 02:46 PM
greekss's Avatar
o btw my car is lowered..... so i figure that these will help alot
Old Jan 25, 2004 | 04:26 PM
z2802sunsetls1's Avatar
since your car is lowered u need relocation bracket,also id get lower control arms and adj pan hard rod and if u want to spend more get a torque arm, id go with bmr or go with the best lgmotorsports
Old Jan 25, 2004 | 07:27 PM
newbie_tace02's Avatar
Lowered = Looks Good + Sh*tty launches.
Fix = LCA's + brackets + panhard (to recenter rear) + strong swaybar + torque arm.
I use BMR and have great results. My car was lowered 1.25" with the Eibach Pro whatevers....
Old Jan 25, 2004 | 09:01 PM
rocketsled's Avatar
Default any pics
just got a set of relocation brackets and would like to see some pic's that way i install them corretly. thanks dennis just send me a pm.
Old Jan 26, 2004 | 12:07 AM
greekss's Avatar
will there be a noticable diff with the relocation brackets ? Cuz for now thats all in addin
Old Jan 26, 2004 | 11:05 PM
greekss's Avatar
anyone
Old Jan 29, 2004 | 09:32 PM
2w0s060's Avatar
I noticed a big difference on mine with them installed and it isnt lowered yet. Alot more traction and less wheel hop.
Old Feb 1, 2004 | 02:48 PM
02Z28's Avatar
where do you get the relocation brackets from?
Old Feb 1, 2004 | 06:02 PM
rocketsled's Avatar
ls1speed is where i got mine.
Old Feb 2, 2004 | 11:27 AM
2w0s060's Avatar
this is what I got,Try ebay...trust me...excellent brackets
http://cgi.ebay.com/ebaymotors/ws/eB...ESSE%3AIT&rd=1
Old Feb 2, 2004 | 01:36 PM
jimmyblue's Avatar
Moderator
I just put BMR bolt-ins and boxed arms on my car. I spent 8
hours doing rear springs/shocks, PHR, LCAs & relo brackets
including some time out for painting the work areas of the rear
with POR-15 (save the rest for later).
You cannot get the bolt-ins wrong. The weld-ins, you can,
and I saw some fugly pictures once. You can weld the bolt-
ins if you want.
You only need to get the rear in the air, loosen the sway bar
and swap away. I used a Dremel to cut the welds so the
brake bracket is clean gone, and dress down the weld bits
left (will paint later). Looks clean.
I see a real difference in traction using the lowest hole and
have not seen any downside yet.
I picked up the relo brackets used at about half retail. Not like
they are a wear item. Saves me the trouble of adding my own
rust.
