Strano Peformance Parts Handling Packages--New prices, new items
HP1: KYB AGX Shocks + SP141 Lowering Springs: $654.99
HP2: SLP Bilstein Shocks + SP141 Lowering Springs: $679.99
HP3: KYB AGX Shocks + SP141 Lowering Springs + Strano Performance Hollow Sway Bar set: $1049.99
HP3.5: (yes it's a new addition and it's easier than re-numbering the rest):
SLP Bilstein Shocks + SP141 Lowering Springs + Strano Performance Hollow Sway Bar set: $1069.99
HP4: Koni 4/3 + SP141 Lowering Springs: $1079.99
HP5: Koni 4/4 + SP141 Lowering Springs: $1179.99
HP6: Koni 4/3 + SP141 Lowering Springs + Strano Performance Hollow Sway Bar set:
$1469.99
HP7: Koni 4/4 + SP141 Lowering Springs + Strano Performance Hollow Sway Bar set:
$1569.99
Go to www.stranoparts.com and look up the year and model of your 4th gen. Then click on "Discount Combination Packages" from the menu on the left side of the screen and you'll find these as well as other combination (including brake, traction, and chassis stiffening packages too.
$1469.99
$1569.99
__________________
lol sam, i hate you! my finger is itching to order that last package since it's 50 bucks cheaper than it was earlier.
how long are you running this promotion? i was looking to purchase within a month or two. just put headers on so i'm out some scratch til i get a few pay days in.
Thats HP1 is tempting, my stock stuff has 106k miles on it.
I can tell you that historically November is busier than October so I'd suspect that the deal I'm getting will end by then.
__________________
You'll be more than good...
__________________
I have a question, how does that HP1 package handle? i have those shocks already but i dont know what springs are on my car, cant find a name thier just red, maybe cut stock ones, but anyway the ride is terrible. Cornering is terrible on anything except a flat smooth road, if i hit a slight bump on a turn the damn car feels like it wants to jump to the out side lane... ive played with the setting on the shocks, and i get either a extremely rough ride, or bouncy or both...so im wondering if i get your springs it will help
I'll do my best....
__________________
__________________
How does the HP1 package perform and ride compared to the HP2?
HP2 is your definite better riding setup as the shocks are just better for that. Valving is better for ride, more piston area than the AGX's. But the Bilstein's aren't adjustable for those wanting to mess around with things. Purely on ride, I'd recommend the HP2 over the HP1 any day.
__________________
Red? My guess, BMR, Eibach Sportline or DMS springs. I'd need to know more about what your shocks are set like (and what you've tried) and some other details. I'm sure my springs wouldn't hurt, but I can't honestly tell you they'll transform the car as the shocks are a lot more of an issue than some differences on springs (assuming not absolutely terrible springs).
When I first got the car the guy didnt know what the suspension was, I discovered they were adjustable that weekend when I was changing the oil and they were set on 8 (full hard) all 4 corners, so I set all of them to 4, still rode pretty rough, then I tried 3 in the front and 2 in the back, the rear end would bounce more then the front so I set the rear up to 3, and I believe thats what they're all set to at the moment. But it still rides like crap, when I go over a bump its rough and it sounds rough, but then its bouncy like its too soft...I would think if its going to be rough it wouldnt be bouncy or vice versa. Its worse then my 93's 134kmile old suspension
Another reason the koni SAs are worth it, they adjust only rebound and the compression setting is static.
Something that may help the ride is checking if your tire pressure is right (30psi all around).
This is one of the problems when you have one **** to adjust both compression and rebound at the same time. Giving it more rebound will get rid of the bounce, but since you are also increasing the compression setting you get a rougher, more choppy ride...
