Is this spacer thing necessary between upper CA/shock mount and body? Pics inside...
So doing shocks springs from the PO one side had this spacer thing and the other didnt. I didnt put it back in when I changed and I dont notice any problem but what is it for and does anyone sell it individually?
TIA
TIA
I think this is the part :
http://www.autozone.com/autozone/par...122700_0_5060_
Tried to get one from GM last week. Discontinued and no stock (according to my local parts guy). Picked them up at Autozone instead.
The part I posted is sandwiched also. I thought the two bolts and two nuts showed in the picture were included incase you needed to replace them when you removed the shock mount itself. Are you 100% sure on this? In case it matters the part I posted is mostly rubber and seems like it's metal where it slips over the shock shaft.
Gabriel is junk -- had multiple failures of their strut mounts in the past -- their mount bolts are whimpier and the metal inserts don't hold up and broke right through -- wouldn't buy their parts again.
Yes, the dogbone (insulator) goes below part 16 and just above part 15; the other rubber-only part goes above part 16.
Another useless view, the 16 is 3 here:
Here's another picture, probably the best yet, but unclear. This is from the 93-02 Camaro Parts Manual PDF (128 MB), which you should all grab here:
http://www.z28.com/LyleA/93-02%20%20...s%20Manual.pdf
The pieces in post 1 are the "all rubber" units. They fit into the upper control arm piece. They act like a seal to keep water, dust and rocks from collecting in the pocket that the shock nut is in. Moisture still seems to find its way inside, though.
Be sure to pack grease all around that shock nut to keep rust away.
The bigger "steel wrapped in rubber trapazoid piece" is what the shock bolts down to. That piece has to be on there.
Here's a better pic. Notice the small rubber piece on the right? It drops right into the sheetmetal hole with a rubber lip to seal it.
