okay where can i find a diagram on how to hook up the abs block
i bought a car in pieces and all the lines are unhooked and i wanna make sure i put them on there correctly and get is bled correctly is their a writeup or something that tells how
ok here we go i know this much i just did mine
the hole in the back is for your rear brakes.
the 4 on top now:
when in front of the car the one on left left front is the front passanger brake
the one in the front right goes to the driver side brake
the ones in the back are for the brake resivor.
this is for a car with no traction control and a 99-02 camaro. i am 98% sure that i am correct. but if you get the block in there you will see how they go because they are bent to only really go one way. i will go to my garage tonight and check though and let you know, maybe even take a picture.
the 4 on top now:
