Keep front abs with 9in rear?
Is there anyway to keep the front ABS working if you switch to a 9" or 12 bolt or any other non factory rear? I'm talking about 3 channel. I searched, and couldn't find if this has been discussed before.
I'm aware that Moser offers a 3 channel carrier, and Midwest does too, I just think it might take me a good while to get something like that. I was looking at the QP housing, and maybe getting a junkyard center until I can afford another grand on a center section.
Thanks Midwest (Eric?). I would love to have one of your fab9's. When I said it would take a while, I meant for me to save the cash, I wouldn't be to worried about it taking forever for delivery. I'm a currently unemployed machinist, you don't need any help making those nice housings do ya? I've got another thread going about my 10 bolt right now. Such a mess. My new one turned out having a bent axle tube, this week hopefully I'll have a chance to TRY to straighten it out. Nowhere around here does anything like that. The one I pulled out was an open 3.08 gear. I'm hoping I don't have to swap everything over to the old case. Luckily (I guess) it only stripped 3 of the spider gears in it, but it might not even be a good shell. It's a mess. F'n 10 bolts.
LS1Tech Premium Sponsor
in order for your abs system to work at all, all of the factory installed sensors have to work correctly. if even one of them is missing or reading incorrect it will shut down the entire system. we can do the 3ch abs system install on our housing, and then you can have us do a center section later, but you can't use any other manufacturers setup due to different ways of sensor mountings and reluctor wheel installs. I could possibly install a 3ch system on another manufacturers housing, but I would have to have the housing and center section complete and shipping costs of all that will more than likely make it not worthy of doing so. a spool and 3ch is possible... been there done that
Hold on "MidwestChassis" ... you can do 3-channel ABS with a spool??? Is that available on the Moser 9", Strange 60 or Fab 9" or ALL of them? I understood that this was not a viable option with a spool.
106 / 3.70 = 28.6
The sprocket that is on my yoke is 28 tooth 1/4 pitch. The other is a spare I bought and is 31.
