Koni shock questions and pics. Come in!
Trunion King
How did you tighten the shocks? With the springs compressed all the way down? Did you tighten down the rear shocks as well?
I made sure everything was tight and I put everything back like it was supposed to be. When I tightened the shocks the spring was compressed, but not all the way down. Yes, I tightened the rear shocks, but there was room to tighten more. Should I have tightened them down until I barely had anymore room to go? Also, with the front shocks/springs when I tightened the nut to the rubber shoe there was also more room to tighten, but my wrench was having a hard time fitting in there because of the tight fit and having to use the vice grips too. Is there a special tool to tighten this without having to use vice grips to hold the shaft?
You should tighten the front shock nut with an impact gun. The rubber compresses and eventually your tightening down on all metal. You'll feel the nut wanna stop.
Not tightening it all the way will cause a clunk for sure.
