ws6 front struts vs. formula front struts
99Forumula is correct. They are not struts. One of big pet peeves around here is calling the SLA setup on the 4th gen, with its shock and coil, a strut . The third gen f-body came with modified Macpherson Struts, in which the coil was mounted to the lower a-arm, just as with the pre-05 mustang. The thirdgen had a strut, as evidenced by the lack of an upper control arm, and the shock having the strut body to support, and locate the knuckle (spindle).
The fourth gen has a short long arm setup (the SLA in SLA), with an upper control arm, and a spindle, the shock mounts to the lower control arm, and does not locate the spindle.
Long and short, the 4th gens have shocks, not struts.
