Relocation Brackets w/ stock LCA's
Ok, heres the deal...
I am picking up a set of wheels this week, and I wanted to lower the car, to give it good stance with the wheels...
I'm getting a good deal on some Eibach springs and Bilestein Shocks...
BUT... I made a previous post about suspension on my firebird, and I was told, that when lowering it I should def. purchase Relocation brackets, LCA's, and PHB...
I was wondering if I could use Stock LCA's with Relocation Brackets, UNTIL I get enough money to purchase Aftermarket LCA's and PHB?
I also wanted to know which LCA's to get, Adjustable, Non Adjustable, which ones???
Thanks in advance,
Kyle
Thanks in advance,
Kyle
Yes you can run stock LCA's with the Re-lo brackets. I did it for almost 2 years until yesterday when I FINALLY installed my UMI adjustables.
Once you lower the car, you might want to/need to re-center your rear wheels within the wheel well. You'll need adjustable LCA's for that. I have UMI everything on my car and love it. But you really can't go wrong with any other brand either. These are very simple installs s well.
Not at all. Simply loosen the jam nut, then adjust the length of the panhard bar by rotating it with a wrench (this is done while installed). After the correct length has been found, retighten the jam nut. It'll take a bit of trial and error to get it perfect, but an easy task overall.
Hello Kyle,
For a lowered car the relocation brackets are a great item to correct control arm angle and regain traction. They would also work with factory control arms with no issues like others had mentioned.
For control arms, we only recommend needing adjustable when you need to make room for tall tires and gain clearance. Otherwise factory length control arms are just fine.
The other item I recommend for a lowered vehicle is an adjustable panhard bar. The adjustable panhard bar allows you to center the rear end under the vehicle after lowering. This is especially critical if you are running a wider tire.
I hope this information helps!
Ryan
Ryan
Adjusting the PHB as mentioned is a lot more important than adjusting the LCA's, which as Ryan said don't really need to be adjusted at all unless you're changing rears or putting in big tires (or something is really off from the factory)....also, the slots on the LCA brackets are placed in an arc on most designs so placing the bolt on a lower hole doesn't really shift anything fore/aft.
