LCA relocation brackets or no brackets?
Old Jan 12, 2011 | 07:44 PM
mcalus's Avatar
Default LCA relocation brackets or no brackets?
I just picked up a set of used LCA's and I am wondering if I should get some brackets too or not. I am lowered if that makes a difference?
Suggestions?
Thanks in advance.
Old Jan 12, 2011 | 08:48 PM
ajsfirehawk's Avatar
If you are looking to minimize axle hop when you launch, then you should consider getting LCAs, especially on a lowered car.
Old Jan 12, 2011 | 09:01 PM
mcalus's Avatar
I have LCAs. I am wondering if i should get the relocation brackets too.
Old Jan 13, 2011 | 12:20 AM
01ssreda4's Avatar
Cant hurt, can only help.
Old Jan 13, 2011 | 08:11 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
dollar for dollar probably one of the best traction mods you can do. we manufacture our own in-house design and are the best bang for the buck. whatever you do don't use any of the bolt-on's. the weld-on design is the only way to fly.
Old Jan 13, 2011 | 09:47 AM
mcalus's Avatar
why not bolt ons? I would like to use bolt ons incase my rearend goes it will be much easier to swap.
Old Jan 13, 2011 | 10:19 AM
SS SLP2's Avatar
as you are lowered , yes you need brackets, as to bolt on they are a problem to keep tight if they work loose THEN you may weld in
Johnny
Old Jan 13, 2011 | 11:01 AM
mcalus's Avatar
Johnny
what about locktite?
Old Jan 13, 2011 | 03:23 PM
MidwestChassis's Avatar
Locktite, and locking nuts are always a safe bet for any suspension piece regardless. The problem is we have just heard to many people mention over the years about constantly having to tighten theirs up.
Old Jan 13, 2011 | 03:34 PM
BMR Tech's Avatar
We have sold bolt-on style relocation brackets for over 10 years and not had an issue with them being retained using bolts. I don't even know if it's possible as the locating bracket bolts on behind the lower shock mount. Haven't heard of peoples shocks falling off....
The bolt-on relocation brackets work on both the factory rear ends and the Strange units.
Moser is the only one I am aware of that requires a weld-on relocation bracket.
Old Jan 13, 2011 | 04:46 PM
iWon's Avatar
I spoke with UMI about a proper suspension setup for my car, and they said the brackets are not necessary. My car is lowered with an Eibach pro kit, adj panhard, adj torque arm, non adj LCA's, weld in SFC's.
Old Jan 13, 2011 | 05:41 PM
mcalus's Avatar
Well I am picking some up used from a member for 60 bucks. They are bolt on, if I have issues I can always weld them.
Seems like this is an undecided issue to get brackets or not...
Old Jan 13, 2011 | 05:54 PM
iWon's Avatar
If I were you, I would do everything BUT the brackets, and see if you have any issues with wheel hop. If you do, get em. Otherwise they are pointless IMO
Old Jan 13, 2011 | 06:12 PM
99FormulaM6r's Avatar
One of the problems with brackets is if you have the rear side of your LCA's too much further down than the front's it can actually increase oversteer (something our cars don't have a shortage of IMO). The key is finding a balance between the two. As iWon mentioned, do install your LCA's and see if you have wheel hop. If you don't, the brackets aren't really necessary. If you do, put them on and see what you get. Being you already bought some, if they're a bolt-on design, it will be really easy to see if you need them or not.
Old Jan 13, 2011 | 06:49 PM
iWon's Avatar
Yes sir ^
Old Jan 13, 2011 | 10:34 PM
wrencher's Avatar
wrencher
I have about every susspension mod there is, except brackets.
Lowered, tube K, arms, 12 bolt- m6, watts link etc.
No wheel hop 4 me so bracket-less.
Got the handle about the best as possible dont want to mess a good thing up.
Old Jan 14, 2011 | 12:31 AM
01ssreda4's Avatar
It's not a great design, its about the only design that was simple and logical to market to the public. Don't think that high HP cars are running bolt in brackets, or brackets at all for that matter. That shock mount is designed to hold the up and down tension of the shock itself as the rear end moves. When you accelerate, the rear end tries to move forward. The ONLY thing that pushes the car forward is the lower control arms. Now, if you mount them to an extender type bracket thats bolted in, what keeps the backet from spinning backwards? The bolt through the top? Nope, the extra extender that reached for the shock bracket. So now we are subjecting this bracket to forward/rearward motion as well as the normal up/down motion. That shock bracket is the only thing keeping those bolt on relo brackets from spinning rearward on accel. Now, ARE we actually overpowering that little shock bracket? Who the hell knows, if they aint snapping off I guess not.
Old Jan 14, 2011 | 08:32 AM
UMI Performance's Avatar
I am with you on this Lee as well. We have been offering the bolt on brackets as well for a few years and no issues. If a vehicle is running in the single digits welding is going to be recommended and always the best no matter what product. A street car will have no issues with a bolt on set of relocation brackets...
Old Jan 14, 2011 | 09:02 AM
BMR Tech2's Avatar
So much bad information in this thread I don't even know where to start. Wheelhop is not the only reason to use relocation brackets. It's all about anti-squat and weight transfer. Wheelhop is only one symptom of a bad instant center. Lowering the car upsets the anti-squat characteristics and the only way to fix that is with relocation brackets. Another thing people don't realize is that this is not just a problem for drag racers. Too little anti-squat produces understeer in corners. Relocation brackets moves your instant center rearward, increasing anti-squat.
As 99FormulaM6r pointed out too much anti-squat produces oversteer. This is absolutely correct and is exactly the reason why you have multiple holes to choose from. Most autocross and road race cars will probably never use the lowest hole but almost all lowered cars will benefit from the middle hole. Drag cars that have enough tire under them, proper weight distribution, and enough power to run a high anti-squat will almost always use the lowest hole. In fact most of the fastest cars being built now have custom fabbed rearends and are using brackets similar to a 4 link with multiple control arm holes for fine tuning anti-squat characteristics.
As for bolt-in brackets loosening or being a poor design, let the numbers speak for themselves. In the 13 years we have been in business, we have shipped 1000's of bolt-in relocation brackets and I have yet to hear of one moving because the bolts wouldn't hold them. The design itself prevents it, not the tightness of the bolts. I've seen bolt-in brackets bend when they were overpowered which is why we really only recommend them for stock to moderate power levels and have weld-in brackets for higher powered cars. That being said I know of plenty of customers running 10's with bolt-ins. Do we recommend it? No, but it happens. The nice thing about the bolt-ins is that you can install them in your driveway and get immediate results. If you switch from a stock rear to a Strange, you don't have to buy more brackets, just un-bolt them and transfer them over. If you have say a 300-450 rwhp car you will be fine with bolt-ins. As your power levels grow, there is no need to buy different brackets, just weld on the bolt-ins....
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jan 24, 2011 | 08:45 AM
dubga's Avatar
This is the kind of information I like to see posted by you guys. I was working yesterday on installing some of the BMR suspension pieces I got during the black friday sale. I have been struggling to figure out what settings to use. I was planning to call today and ask for some help. What you just posted here taught me a lot about the effect of instant center.
I already had a set of BMR springs, and recently purchased the bolt-in relocation brackets, control arms, adjustable torque arm, and torque arm relocation crossmember.
I have the springs installed, and the bolt-in control arm relocation brackets with the control arms in the center hole. Last night I was installing the torque arm and crossmember. With my car being lowered, which holes would you recommend to start out with the torque arm mount adjusted to? I know you can't dial-in my suspension for me, I'm just looking for a good starting point. I understand the setting and effect of the pinion angle with the adjustable torque arm, but I am fuzzy on instant center since it is affected by both the control arm angle and the torque arm mount position.
I am just bolt-ons and don't plan on really big power. Should I stay with the center hole on the relocation brackets? And which holes should I use on the torque arm relocation mount?
