please help
Old Feb 15, 2004 | 06:12 PM
krauSS 02's Avatar
Default please help
for some reason i am hacing alot of trouble with my 60 ft times.
the suspension work i have done is:
an 1.5-2 inch drop
adj. shocks
i know that i need alot of work, but but would be the best next move.
and who makes the best suspension parts.
Old Feb 15, 2004 | 08:24 PM
trackbird's Avatar
LCA relocation brackets. Buy them from the same place you plan to buy your LCA's from.
Old Feb 15, 2004 | 08:54 PM
glitch77's Avatar
Bingo.
To elaborate a bit, when you lowered the car, you decreased the angle of the lcas, the relocation brackets move the bolt holes lower on the axel, to compensate for the axle being 'higher' (compared to the car), thus restoring the origional angle.
Old Feb 16, 2004 | 10:57 AM
krauSS 02's Avatar
So What Do You All Think Should Be My Next Move
Old Feb 16, 2004 | 12:24 PM
tuffluck's Avatar
they just told you - lca relocation brackets, and accompanying lca's.
Old Feb 17, 2004 | 10:33 AM
krauSS 02's Avatar
i ment after the lca's
Old Feb 17, 2004 | 11:04 AM
Tranzor's Avatar
Like the others said, get the LCAs and LCA relocation brackets... after that, go with an aftermarket torque arm. Also make sure you get some sticky tires, like Nitto drag radials... that will help with traction too.
Old Feb 18, 2004 | 09:54 AM
krauSS 02's Avatar
any comments one who has the best lcas and torque arms?
