Subframe Connectors?!?!?
Old Apr 13, 2011 | 02:46 PM
Camaro Z.'s Avatar
Default Subframe Connectors?!?!?
Which subframe connectors should I get, bolt-in or weld-in?
Old Apr 13, 2011 | 02:59 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
Weld-in is going to be your best bet as far as solidifying the chassis goes. You don't see any super fast cars running bolt-in subframe connectors for a reason.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Apr 13, 2011 | 03:07 PM
Camaro Z.'s Avatar
Ok thanks for the fast response
Old Apr 14, 2011 | 06:23 AM
UMI Performance's Avatar
It depends on your driving and how you are going to use the car, less severe use would be okay with bolt in styles. Like Kyle mentioned welding is always going to be best however not everyone has access to a welder all the time so this can be difficult. A lot of the customers will purchase bolt in styles and have them welded at a later date, which is possible.
I hope that helps,
Ryan
Old Apr 14, 2011 | 09:22 AM
6speedt/a's Avatar
I have found from personal experiance buy the bolt in style.....but get them welded in when you get a chance. Its alot easier to weld them when they are already bolted to the car.
Old Apr 14, 2011 | 10:18 AM
Paul 1953's Avatar
^^^^ may be a good idea.
I have slp welded SFCs. They are very HEAVY. I don't know if that's an issue for you. I was surprised (years ago) when I unwrapped them and took them to the speedshop for welding. But otherwise they perform great. You'll definitely notice the enhanced stiffness.
Old Apr 14, 2011 | 10:50 AM
skimms98's Avatar
I have the UMI weld ins and love them! It made a big difference in stiffness on my Formula.
Old Apr 14, 2011 | 10:58 AM
BrianSF-GA's Avatar
x2 on the UMI weld-ins.
Old Apr 14, 2011 | 12:48 PM
toadzq8's Avatar
BMR weld-in Boxed. I like the fact that their design ties into the control arm mounting location on the frame making it much stronger.
Old Apr 14, 2011 | 01:01 PM
*02WS6TURK*'s Avatar
3-point UMI bolt-in FTW. Love mine. If you ever need to remove them, it will be a lot easier.
Old Apr 14, 2011 | 02:53 PM
Badazz 97 TA's Avatar
i have 3pt bolt ins and had 2 pt bolt-ins previously. It was nice being able to install it myself. Then like UMI said you can always weld them in afterwards.
Old Apr 14, 2011 | 03:43 PM
Regulator's Avatar
Do the bolt-ins mount up to the same locations as the weld-in? And do the 3-point SFC's cause any clearance issues with exhaust or torque arm relocation crossmembers?
Old Apr 14, 2011 | 04:54 PM
Exactly
You should have no issues w/ clearance. I'm running Pacesetter LT's, Texas Speeds ORY and have zero issues. Also have the UMI torque arm w/ relocate bracket. Everything clears just fine.
Old Apr 14, 2011 | 09:25 PM
UMI has pictures on there website of the subframes mounted on the car. search there site. yes they are the same thing just without the bolts for the front. the 3pts dont interfere with anything.
Old Apr 15, 2011 | 12:13 AM
RevGTO's Avatar
Pontiacerator
+1. If you have bolt-ins and you decide you don't like them, you can easily take them off. Not so with weld-ins.
Old Apr 15, 2011 | 07:28 AM
Hello,
Like mentioned by a few others the 3-Point SFC's will have no clearance issues at all and we haven't found a single exhaust system they won't clear with.
I hope that helps!
Ryan
