Suspension EXPERTS... I need help
I have a 2002 Ws6 That I had lowered. It has the Edelbrock lowering kit on.
Basically the ride is to rough on bumpy streets, Can I change the shocks only on this kit for a better ride ?
If so what are the best ones to go with ?
thanks Warren
thanks Warren
Warren,
Yes the shocks being changed will make a night and day difference on the vehicle.
I am not real familiar with the Edelbrock springs but lowering springs and factory shocks don't make a great pair.
I would recommend a set of SLP Bilsteins or Koni's, Koni being the best but also most expensive. Strano Parts is a great shock distributor with excellent recommendations, try Sam- www.stranoparts.com
I hope that helps,
Ryan
I hope that helps,
Ryan
Warren,
I hope that helps,
Ryan
I hope that helps,
Ryan
The Edelbrock shocks are fairly crappy IMO.. Especially when compared to a quality Bilstein or Koni.
Koni Single Adjustables would probably be your best bet for a quality shock that will bring back a decent ride quality.
Good luck
Hi,
the previous post are correct. However, low profile,wide tires will have more road noise and ride quality sacrifices than standard side walls. We give up ride quality for that stealth look. Best of luck with your decision and have a blessed easter. Jim
