Roto-Joints
Whats worse is that twice now, I've had to re-assemble the roto-joints on the right LCA because they completely disassembled. First time, the front roto-joint fell apart. The second time, the rear roto-joint fell apart. Nothing was missing, all the parts where there. I just had to clean/re-grease/re-assemble (which isn't fun when its raining... funny how it started raining both times I went to repair them).
I did a search, but I couldn't find any threads on this. If there are threads on this, please post links to them.
I've been considering some of their parts for my setup, but havn't bit the bullet yet; just waiting for someone to have issues. Thanks for posting up.
DR Crame
2006 Dodge 2500 (sold)
2009 F350
2001 Camaro
2006 GT Mustang
If you have an older design PM me and I will take care of it.
As for Delrin, we have no issues using Delrin in the Roto-Joint, we are pleased with the performance of Delrin in the applications we are using it. The older style Roto-Joints are a locking issue and not a material choice issue.
Thank you,
Ryan
Handling is like a rod-end.
Think of it as a less harsh rod-end that you can tighten up as it wears.
I'm just concerned with how this earlier design opens up.
I'll let you know how the new design compares to the old design.
I bought a set of the "Johhny-Joint" equipped LCAs for my Z-28, primarily to correct a slight thrust angle mis-alignment, and also to allow the freer movement of the rear end. While they did this, I found them to be too harsh for the street, and took them out last week. I'm considering selling them....
My rear was also a bit off with the stock components so I needed adjustables to straighten it out.
I went with the UMI roto joints and they handle great but because my car is a daily driver and the roads on city streets are not that great where I live, I really found them to be too harsh and noisy for daily driving, so I'm going back to poly.
One thing to consider....Since the 4th gen F-bod uses a panhard bar to control the side-to-side movement of the body, the LCA have to travel in an arc that is defined by the PHB. Therefore the body and LCAs do move back and forth about 1/8-3/16" during normal suspension travel. If the bushings can't/don't flex, something else has to. That "something else" becomes the mounting tabs on the body and rear axle.
As much as I know the poly bushings provide more stability, they also "work" the body of the car quite a bit more than the OE rubber bushings do. Just something to ponder....
