Problem under hard braking
Old Apr 26, 2011 | 06:36 PM
V68Sweep's Avatar
Default Problem under hard braking
Ok, so my brakes work just fine under normal braking, but under hard braking I get a terrible "notchy" feeling in the pedal, and my braking distance increases because it feels like the pedal can't make full depression because it gets...knocked up and down I guess. I do not have warped rotors, and I scanned it with a Tech 2 and there are no ABS codes and no history of ABS codes, but I've been told it's probably an ABS problem...could it be mechanical? I am scared that the problem will get worse, then one day I won't have brakes when I really need them!
Old Apr 26, 2011 | 06:55 PM
Lt1Porsche's Avatar
You have either warped rotors or a high/low spot on one of the rotors. Or its just ABS kicking in.
Old Apr 27, 2011 | 08:44 AM
wssix99's Avatar
Save the manuals!
Is it your ABS going off? If you aren't sure, can you try a hard stop on a wet parking lot or something like that to confirm the feeling?
If its ABS and you have no codes, you may just have a sensor reporting bad information and causing the system to trigger.
If you can recreate the issue in a safe place, maybe you can pull the ABS fuse under the hood (I assume that's where it is.) to deactivate the system and see what happens?
Old Apr 27, 2011 | 12:02 PM
V68Sweep's Avatar
I can and have recreated it a 100 hundred times, it's so easy to do. That might actually be a good idea-I don't know where the fuze is, but I can find out! Thanks!
Old Apr 27, 2011 | 02:51 PM
BoricuaHec01's Avatar
Formally Simplɘ Jack
I wonder if this is the problem I have. A few weeks ago I changed on my rotors and pads, the braking in normal speeds feels fine but when I go fast and do a hard brake it feels and hears like the brake pads are grinding or something. Hopefully nothing is wrong :/
Old Apr 27, 2011 | 03:19 PM
CorbinLR's Avatar
How do you know you don't have warped rotors? You won't be able to tell be look or feel unless they are warped pretty good.
I only say this because it sounds like warped rotors.
Old Apr 27, 2011 | 04:39 PM
V68Sweep's Avatar
Well I've had warped rotors before and it was a very clear pulsating feeling going through the whole car. My problem is a very rapid notchy feeling (I wish I had a better word for it) only in the pedal. And there's no grinding noise really, just...I don't know how to describe it, but it's not grinding lol. But nonetheless, I'll double check the condition of my rotors just to be sure.
Old Apr 27, 2011 | 07:39 PM
I have no other way to describe it either lol.
