Help/tips on how to adjust QA1's ride height
I feel like a dumbass for not researching the install prior to installing my QA1(12 way adj/300lb) front coilover setup and even worse for letting someone else do it for me! So I've been too busy with work and my cousin offered to install the coilover setup. They were already on the car when I got home and the front of the car was slammed(couldn't fit a finger between tire and fender) to the ground. So I say no problem let's just jack it up, take off the wheels and adjust it with the spanner wrench. Well that was easier said then done. It was hard as hell to turn that wrench and only got harder as I turned more n more! Turned and turned and barely managed to get a finger's distance between the tire and fender! What am I doing wrong or how do I go about adjusting it to get it a little higher? Do I have to take them completely off and adjust them while off the car or what? I already tried researching but found nothin of this sort. Help would be appreciated guys! I've read about people saying these don't really lower their cars much so why is mine the total opposite?
1 Post
-if you lift the car off the ground, it will take most of the pressure off the spring.
-spray the threads and the top surface of the perch with wd-40 to help it slide (i too was a dumbass and didnt get the bearing kit... kicking myself in the *** for that one).
i was able to muscle through it... but it wasnt easy. if you are having a hard time, it would be 100x easier with the wheels off, but you gotta keep lowering the car to check the height... so maybe you just loosely spin on a couple lugs just to set it down.
another option if you are struggling, is to put a set of spring compressors on the spring to help take the pressure off.
also remember that you gotta bounce the car a bunch to let it 'settle'. even then, it might sink a bit more after you drive it around the block. i thought i had mine even with the back, but after driving it around, i think i need to come up another centimeter.
Please educate me as to what that is and how it would assist me in my problem. Please pardon my ignorance but I just researched it and got nothin but but bearing kits for trannys!
It is a bearing that goes on the top perch. It goes between the perch and and the spring itself. Link below has a picture of one and you can see how it could help a lot. I got mine from a local race car shop for $25 but they are available all over online.
http://www.google.com/products/catal...=1345&bih=612#
