Vibration Felt - Measuring Pinion Angle without Lift.. S&W adjustable torque arm
I've been chasing drivetrain noise/vibrations since I've got the car and I'm starting to get it under control.. I just replaced my u-joints and had my driveshaft balanced which helped some. The transmission mount helped quite a bit, but the next thing I'm going to try is adjusting my pinion angle. God knows if the previous owner did. I saw a BMR video on how to do it, then read somewhere that the video has been corrected and I can't find that updated video.. Also is there anyway to get underneath the car to measure it without a drive on lift?
Thanks!
Thanks!
for what its worth, i use rhino ramps, i then measure the distance from the ground to the top of the wheel, through the center, and then jack up the back by the pumpkin to the same height.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You don't want to do pinion angle on the rack, you need
all 4 loaded normal. I have 4 Rhino ramps and last time I
did this I put the car up on all 4 so it was just like on the
driveway, only with room to breathe.
