Painted Calipers.
Old Jun 7, 2011 | 11:04 PM
Jmg93's Avatar
Default Painted Calipers.
Does anybody know where to buy painted calipers?
Old Jun 8, 2011 | 01:07 AM
lethal bird's Avatar
Autozone it comes in a can.
Old Jun 8, 2011 | 09:08 AM
ShortChevy's Avatar
You can send yours out to get powered coated. Looks awesome but $$$. Or you can nut up and go to vatozone and get a kit and do it yourself.
Old Jun 8, 2011 | 10:58 AM
Jmg93's Avatar
Well i did it myself last summer and they turned out good, but now over time the paint is chipping and fading.
Old Jun 8, 2011 | 03:12 PM
99zee's Avatar
What paint did you use? Did you do any prep? I did mine over 5 years ago and they still look the same as the day I did them. I ground the casting marks off and smoothed them out. A couple coats of primer, paint and clear.
Old Jun 8, 2011 | 05:37 PM
JD_AMG's Avatar
x2 ^ on the above post.
Prep goes a long way, # of coats you put on, and paint quality (make sure it is made for heat, like caliper specific paint).
I painted my stockers years ago (maybe 3 or 4?) and they have no chipping or fading issues. All I did was clean them, sand them to rough up the surface, and then put a few coats on and let them sit over night. Didn't even clear coat it or primer...
Old Jun 8, 2011 | 06:52 PM
zdc590's Avatar
Agreed on the prep. First time I did mine I was 17 or so and didn't know much. All I did was clean them and put one or two coats on, it started chipping a year later. You should definitely sand a bit, clean, prime and do several coats, Maybe clear it at the end if you want but I've had good luck even without.
Old Jun 8, 2011 | 10:33 PM
usnfenix's Avatar
autozone has a high heat resistant paint too that helps alot
Old Jun 9, 2011 | 12:03 AM
I used engine enamel . Works just fine.
Old Jun 10, 2011 | 01:30 PM
Jmg93's Avatar
Does anybody have a write up on how they did theres and what products they used? Did yall fully disconnect the caliper from the brake hoses too?
Old Jun 10, 2011 | 05:15 PM
99zee's Avatar
I did not disconnect the calipers. I used a dremel to smooth the casting marks. Then cleaned with degreaser and washed them off. Used compressed air to dry them off. I used newspaper and plastic bags (Walmart, etc) to cover everything up. I sprayed a couple coats of primer, paint and clear. I used caliper paint from Plasti-Cote. (think that's what it was) Any high heat paint will work fine. Very easy, just time consuming.
Attached Thumbnails Painted Calipers.-rotorf1.jpg   Painted Calipers.-rotorf3.jpg   Painted Calipers.-rotorr1.jpg   Painted Calipers.-rotorr2.jpg
Old Jun 11, 2011 | 12:24 PM
Jmg93's Avatar
What would you use to remove previous paint?
Old Jun 11, 2011 | 12:32 PM
Duffster's Avatar
If you go to the appearance section and search for this, you'll see dozens of threads.
