Just installed BMR springs, not happy with rear *pics*
^ Anyway you could post some good profile pics on level ground PLZ.
edit: Oh ya, and sell me that Humount if you havent already PLZZZZZZZ.
Im planning on running the BMR springs also so this thread had me hella scared at first, but im glad to hear the 9'' is more than likely the culprit for your miniature redneck rake. Either way the car still looks MUCH better OP, are you still on stock springs?
TECH do all aftermarket rear ends(MWC, S60, 12 bolt, etc) raise the stance in the rear or is it just the Moser 9"?
GM Axles have an OD of 2.625", most 9's and 12's, etc use a 3" axle tube. That's a difference of less than 1/2" total, and since half of that is underneath the axle that makes no difference on height. Yes, bigger axles raise the car... but comparing diameters it should be on the order of 1/4" or so unless the spring perches are hugely thick.
I just ordered the yellow Koni's and BMR 1.25" drop springs for my car. I too have a Moser 9" I didn't know that the rear end would sit a little higher because of it having the 9". I'll do the hose mod when I install the rear springs and see how it looks.
