Best F-body brakes for 17" wheel stock offset
Old 07-16-2011, 08:37 PM
trans_am7935's Avatar
Default Best F-body brakes for 17" wheel stock offset
so i was intrested in the CTS-V calipers and 14" rotors, but they wont fit under my wheels, so i was wondering what is there best brakes that i could shove under my 17" WS6 wheels?
Old 07-16-2011, 10:50 PM
i know there was a link on here where the CTS-V brakes were fit under 17" wheels, but the link was dead. so does anyone know how to do that? i assume some grinding would be in order
Old 07-17-2011, 01:48 AM
Snake_Skinner's Avatar
Why? Pretty sure the CTS-V brake swap will fit your 17's fine.
edit: Boy was i wrong.
https://ls1tech.com/forums/suspensio...fferent-5.html
Old 07-17-2011, 01:52 AM
i read in the sticky that is requires 18" wheels and spacers, i dont want to ditch my Z06 wheels or offset my wheels with spacers, so i was just hopping for a bolt on upgrade. i know the C5 brakes fit 17" wheels but i think my sloted/drilled rotors and HPS pads to that would not be such a good up grade.
if the CTS-V brakes do fit, do you know who else has put them under 17" wheels?
Old 07-17-2011, 02:26 AM
I was mistaken sorry. good thread here too though: https://ls1tech.com/forums/suspensio...-kit-info.html
Old 07-17-2011, 02:24 PM
SVThuh's Avatar
You would probably be best off going with a C5/6 conversion kit (non-Z) or if you dont mind spending a bit more for a 4 or 6 pot setup, Wilwood or Stoptech would be my #1 choices.
Old 07-18-2011, 11:57 AM
sjsingle1's Avatar
i think the wilwood kit will fit under 17s.......but 2000$ for a front kit is kinda pricey in my bok
Old 07-18-2011, 06:00 PM
SVThuh's Avatar
It usually does fit.. Especially on stock (style) wheels.
The brakes are worth it though.. Most people will spend that much money on stuff to make their car go faster, hell a good braking system IMO is worth more than that, unless your just drag racing and trying to stunt.. lol.
I love my Wilwoods!
They even fit under my 17" Enkei Win's which are notorious for not fitting bbk's.. The 12.2" kit JUST barely clears them, but they work great and still offer much better braking over the stock system.
Old 07-23-2011, 12:21 AM
great421's Avatar
Default My $0.02
Before you start throwing large amounts of cash at your car by replacing the entire brake system, upgrade your pads and see how that works - I just installed EBC Yellowstuff brake pads (front and rear) and all I can say is WOW!
Old 07-23-2011, 01:00 AM
i have bremo drilled/slotted rotors and HPS pads. they work pretty good, but i have 17" rims, cant fit the CTS-V brakes under there, was looking for another cheap upgrade. if i can not find one i will just keep what i have
Quick Reply: Best F-body brakes for 17" wheel stock offset
