Odd idea...more steering angle from a 4th gen?
Old 08-31-2011, 12:21 AM
Raptor_WS6's Avatar
Originally Posted by studderin
I modded my upper mounts, and the rack. Had to remove the wheel liners for full movement. That and the LPE 2step are the best things I did for drifting
more info pls
Old 08-31-2011, 11:22 AM
Fury_786's Avatar
Originally Posted by Nick V.
i noticed the splitter setup you had and i was like....forza?. XD
but anyway nice vid. and i hope you find a way to mod your front end cuz that will add a ****-ton to the list of the things we can do in these cars.
im gonna figure it out lol...btw, got another forza vid in the works
http://vimeo.com/28293537
Old 08-31-2011, 05:52 PM
JD_AMG's Avatar
Search this topic, its come up before. 3rd gens are supposedly easier to get more angle, but 4th gens are supposed to be more tricky.
Old 08-31-2011, 08:42 PM
Fury_786's Avatar
if you search...and go back a couple years...theres nothing i could find relevant or helpful
Old 10-03-2011, 05:24 PM
Fury_786's Avatar
well after some messing around i discovered that my brake calier brackets (c5 adapters) were hitting the front lca...so i made some adjusting to the arms, drilling 2 small holes so that the bracket/bolt go all the way to crank lock.
ive also ordered stuff to extend the inner tie rod end. it looks like with extended inners and some aftermarket LCA's it is going to turn considerably farther
Old 10-09-2011, 04:40 PM
loki_the_adept's Avatar
keep us posted. the turning radius is truly lacking and a fix would brighten my ride!
Old 10-09-2011, 07:07 PM
Fury_786's Avatar
im currently working on some inner tie rod end spacers should be done this week hopefully...had to get parts from the UK lol
and im putting some 1.5" spacers on the front to help clear the lca and the sway bar.
im going to be upgrading the front sway bar and switching over to tubular control arms soon too.
Old 10-20-2011, 08:03 PM
blewbyouss's Avatar
Any new news on this yet fury?
Old 10-23-2011, 07:22 PM
Fury_786's Avatar
Added a UMI front sway bar and 1.5" wheel spacers to give some clearance.
still have to get some tubular LCA's cause the brakes are going to hit the control arms.
other than that i have 25mm inner tie rod spacers, so with that there should be another 20-25* of steering angle. i was gonna have it all done, but i blew up another 9" third member so im now waiting again lol. hopefully have this complete in a couple weeks
Old 10-23-2011, 08:48 PM
A502slo's Avatar
http://www.youtube.com/watch?v=bbNHnE_m0Vo
Yea i know what you mean. 1st time in this car and not to bad.
Old 10-23-2011, 09:55 PM
A502slo's Avatar
Old 10-23-2011, 11:01 PM
  #32
LilJayV10's Avatar
Damn that looks like fun. I gotta learn how to do that.
Old 10-24-2011, 05:42 PM
  #33
Fury_786's Avatar
went out the other day and did a little messing around...my friends have some vids ill have to get.
but these are from our last event. about 35 cars and ~400 people showed up, one pro FD driver cam and ran his car to t&t also
Old 10-28-2011, 06:21 PM
  #34
cDorch's Avatar
subscribed for pics, results, and a parts list
Old 11-11-2011, 03:02 PM
  #35
dirtykidcustoms's Avatar
Building a drift specific 1996 Z28 SS Car and first topic addressing is the steering angle and increasing it dramatically. Ive been all over this post and numerous others for some time looking for options and decided to go ahead and modify the stock rack to work given the geometry is all ready there minus the limits in the actual working parts them selves...Still look forward to your results Fury and what you got to work for you since mine will take a little bit of time as I head back to Afghanistan next week for a couple of months but the machining and parts moding will be done so when I get back hopefully I can get you the results and all interested...Going for the option to be able to take a factory rack and with a little machining and a couple of mods (all cheaper then just the after market racks alone) then hopefully we can see some more of these on the track soon...
Old 12-01-2011, 07:53 PM
  #36
rjlawlor646's Avatar
any results on parts and results? very interested in doing this
Old 04-28-2012, 05:21 PM
  #37
TTownTech's Avatar
any luck getting it working better?
Old 09-15-2012, 05:02 AM
  #38
Robbie Wilson's Avatar
I know I am bringing back a dead thread but I am dying to know... to the op did it work? Did you get more steering angle?
Old 09-15-2012, 09:57 AM
  #39
JD_AMG's Avatar
Not the OP, but this guy got more angle:
https://ls1tech.com/forums/road-raci...ift-build.html
Old 11-15-2012, 10:29 AM
  #40
Finally found a place with the right tooling to machine the most important part I could not do myself...and locally at a killer price!...The next step will have to wait till Im back from this deployment rotation but in the 30 days I have off before I have to return I will post up some numbers and pictures as I can to show what we were able to get out of the components...A ton of additional parts have been ordered and on the way as well for install once I get back and going to be a quick break but hopefully right before the new year or a few days after "Lady Luck" should be track/test worthy and will let everyone know for sure how it goes!
Quick Reply: Odd idea...more steering angle from a 4th gen?
