Brake pedal stiff
Brake pedal stiff
I posted in the tranny section that my car wont come out of park. I'm trying to roll it on to a trailor. I have the alternator and coil bracket off, but the battery is still hooked up.
When I go to press the brakes, they are firm and there isn't much to room to "push" and I cant shift my tranny into neutral.
The car hasnt moved in 3 months, the brake pedal should "loosen" up some over time, shouldn't it?
I'm at a loss here...
Actually, you need to get some vacuum into the booster somehow. I can't think how other than get another running car close, use 20 ft(!) or so of vac hose and hook up the vac line from running car to your booster? Sounds crazy. Do you have a vac bleeder with adapters to apply vac to the booster perhaps? Someone on here should know...
as for not shifting out of park, the key has to be turned a little before the shifter can move
