My crappy alignment results
Front: caster l&r=4.1 3.9
camber: .4 .6
Toe: .05 .05
Rear
Camber: -.4 -.2
Toe .3 -.3
Thrust: .3
Shop said they couldn't adjust rear camber? Wtf?
camber: .4 .6
Toe: .05 .05
Rear
Camber: -.4 -.2
Toe .3 -.3
Thrust: .3
LS1TECH Sponsor
I was simply going to say "well, they can't".
__________________
"crappy alignment results" which settings is so crappy ?
GM engineers devoted years of research into designing the F-BODY and
I as well as most if not all the ppl on this forman think they did a great job, I do not remenber the exact specs but I think OE specs are close to :
Front
camber + 0,50 with +/- .50
caster + 4.00 with +/- .50
toe + 1/6 in with +/- 1/16 in
Rear
camber 0.00 ???
toe + 1/16 in ???
thrust 0.00 +/- 0.13 ( I like + 0.03)
the way I read the OP specs
camber is close
caster is off a little/opposite side settings - this setting will cause a little pull to right( right side need to be a little ahead of left so car does not follow the crown of the road) toe should be ok
rear camber and toe can not be adjusted ( rear toe is very good 0.00)- close enough that they should not be a problem, rear thrust not too bad rear of car MAY swing out to right if loungh hard, this could be corrected with agjustable LCA
now as to car at OE heigth or lowered I think setting should be closer to OE specs as possible for DD as tires are going to contact the road the same if car is 3" lowered OR 3" higher ( the SAI would change as the angle of the upper and lower control arms will change if lowered/ rased
now to add to this IF running AUTO-X or raceing a winding road, a little - camber and little - toe MAY help the handling of car
just my $ 0.02, I am not "A-SPERT" just because I am 3 times the age of the advadge ppl on this board, but have aligned app 78,000 autos/ and still learning WHEN I stopped
enough of this rambling
Johnny
I'm trying to learn all this alignment stuff. Yes the wheel is straight now and they adjusted toe to proper oe specs but it does pull to the right. They said caster is maxed out.
"... but it does pull to the right. They said caster is maxed out.""
IF caster is maxed out on right, simpley lower caster on left, try to obtain a lower setting about 0.50 on left than the setting on right.
( if right is 3.9 and MAXED out lower the left to about 3.4, if setting are a little under specs it should not cause a problem the main thing is obtain a .50 lower spread on left,how ever the higher caster setting ( up to a point) you obtain the more stability at high speed,However if run too much Caster you will scuff/slide the front tires around a turn rather allowing them to roll around a turn
Johnny
Johnny
+.5 camber in front is around target factory recommendation. I think that value for camber though is a HUGE PIECE OF CRAP!!!! It seems to wear most people's outside edge of their tires. It did with me.
