Full suspension??
If you are doing more handling oriented stuff I would look at shock, lowering springs, and sway bars. These are the parts that really set the foundation for a good handling f-body.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
1 You could buy new stock type frt control arm bushings , anti sway bar bushings, shocks and ball joints. The pros are low cost and decent ride. The cons alot of labor to change the control arm hardware.
2 The rear. New control arm and panhard bushings and again shocks, and bump stops. Lots of labor and again low cost.
3 New trans mount and T. arm mount bushing.
You'll have a new stock riding car again.
For a small performance gain less labor, but more cash. New frt arms with a poly bushing or a bearing . New Koni or Bilstein shocks frt and rear. New 1LE anti sway bar bushings and end links. I'm not sure if you can get them from GM any more.
Poly trans, and torque arm mount bushing.
New lower control arms with poly or rubber. New panhard bar and new bump stops.
If the budget allows an aftermarket torque arm is a major improvement over the stock piece.
2k would just about do all the suspension minus the Koni shocks $$. If you went with the Bilsteins you might fit the T arm into the budget.
Don't over look frame connectors they make a big difference. I've had bolt on ones on the car for 11 years.
Many people agree with the rubber.
Bushings I think are self-explanatory, it's bad when control arms and suspension parts can move around too much.
Shocks, because they are the single most critical part under there for almost everything you want. Most folks hate the floating, the bobbing, the impact harshness, and the generally disjointed feeling that abounds. All shock issues.........
