Has anybody had fitment issues with an aftermarket K member?
I'm getting ready to reinstall my engine/transmission/kmember/front suspension. I went with a BMR turbo K member, and was wondering if I should expect a big hassle reinstalling? I've reinstalled a stock K back under the car a couple times, and it's not like you can really "tweak" the aftermarket K, so I assume it'd have to line up pretty much perfectly as long as it's positioned properly under the car (reinstalling the engine from underneath). The included instructions mention keeping a pry bar handy, so...
Just wondering if I should expect any surprises.
LS1Tech Premium Sponsor
It should be as easy as putting you stock k-member back in the car. The BMR k-member has dowels on it that line everything up and make it easy to bolt in the car.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Anybody make a k member without the adjustable holes for suspension mounting? As in fixed holes for a car not needing the adjust-ability and wanting to run stock arms?
See, thats gonna be a little difficult for me because I am doing this as part of a turbo build and I will probably need to get it tuned just to event run (bigger injectors) as well as an m6 to 4l80e swap, so I guess I will have to get a base tune to drive to an alignment shop then get the really tune once it can drive straight.
